layout:
'hcl'
type:
'Notebook'
hvm:
'yes'
iommu:
'yes'
slat:
'yes'
tpm:
'2.0'
remap:
'yes'
brand: |
Notebook
model: |
V54x_6x_TU
bios: |
Dasharo (coreboot+UEFI) v0.9.0
cpu: |
Intel(R) Core(TM) Ultra 7 155H
cpu-short: |
FIXME
chipset: |
Intel Corporation Device [8086:7d01] (rev 04)
chipset-short: |
FIXME
gpu: |
Intel Corporation Meteor Lake-P [Intel Arc Graphics] [8086:7d55] (rev 08) (prog-if 00 [VGA controller])
gpu-short: |
FIXME
network: |
Intel Corporation Device [8086:550a] (rev 20)
Intel Corporation Device [8086:272b] (rev 1a)
memory: |
97940
scsi: |
usb: |
5
certified:
'no'
versions:
- works:
'partial'
qubes: |
R4.2.3
xen: |
4.17.5
kernel: |
6.6.65-1
remark: |
Tested: touchpad, usb, audio, audio jack, suspend, WiFi, HDMI/External display, ethernet and sd-card reader.
credit: |
JocularMarrow
link: |
Remarks
- Update boot parameter with
i915.force_probe=*. - Recommend to follow this so everything is not tiny: dpi-scaling
- Suspend
1. net-qube fails to start sometimes:The kernel doesn't support reset from sysfs for PCI device. Fix: Increase RAM on the net qube.
2. Touchpad stopped working (might only be on QubesOS i3). Fix:sudo udevadm trigger --subsystem-match=input. I added this as a service so I don’t manually need to write each time. - Screen resolutions other then the built in are not available, follow this for a fix: github issue
- When second monitor plugged in, all windows/qubes that are dragged onto that display the cursor wont work. Fix: Restart affected qube, solution found here.
All seems to work well, other then mentioned above.
