NovaCustom Users, how is your trackpad / touchpad working?
I have a Qubes OS certified Novacustom machine, but I’m really unhappy with the trackpad (and the keyboard, which feels like an air mattress). The trackpad has extremely poor tracking accuracy: the pointer keeps overshooting buttons when I try to click them. I tried resetting it in the mouse and touchpad settings, but that didn’t help.
There’s also an oily stain on the trackpad that I can’t remove, even with alcohol. It seems to have soaked into the surface, which I assume is plastic rather than glass. The trackpad feels rough and jerky as a result.
Have any other Novacustom users experienced this? Were you able to find a solution?
Same for me. quality of Clevo hardware no matter how you get it, from Novacustom or by another reseller.
My V56 is coming up on 2 years old now, and I’ve had no issues, although my keyboard is showing signs of use.
You may need to replace your trackpad, you can buy replacement parts for your specific model on their website. They even have replacement guides for each part.
:sob:
My machine is new.
I hate my V56 hardware:
  • Poor keyboard and screen
  • Unsupported sd-card reader
  • Trackpad has same issue as you mention
  • Stick reset isn’t supported for sys-usb and sys-net
Huge exchange price to have heads on board.
I actually love the keyboard, I think it feels great to type on.
I do wish the trackpad was better quality (glass), but overall it works fine for me.
What screen resolution do you have? Do you have a protector?
I fully agree with you! In fact, I’d recommend that anyone who is hardware quality sensitive and who wants Heads buy a StarLabs machine—or anything other than a Clevo—and send it to Dasharo to have Heads installed, if needed. It costs about $100/€100.
I have a StarLabs machine too, and the hardware is excellent. It’s an AMD machine that was supposed to be ported to coreboot, but AMD pulled back on coreboot support.
I was so unhappy with how StarLabs handled that that I decided to buy a new machine from Novacustom. I wanted Heads, of course. While I do think Novacustom is a great company, I’m really disappointed with the quality of the Clevo enclosure. It’s inferior to any enclosure I’ve used before. In the end, I wanted to punish StarLabs but ended up punishing myself. :sob:
NovaCustom NV41: Battery life at 90%, keyboard and touchpad still as good as new (apart from the sticky finger stains). Some dents, where the silver color comes off at the edges.
Can’t compete ergonomics wise with my mechanical keyboard and gaming mouse setup at my desktop machine, but a very good daily driver.
I also think it’s absolutely retarded that the quality is so bad for the price I paid.
1920 x 1200. Yes, I have a privacy screen that also bugs me because my screen is now like a mirror with tiny dots.
I have the same resolution and it looks great. I wouldn’t recommend the privacy screen to anyone, it is horrible. There are far better options out there.
Actually I don’t even need it, but it seemed like a nice extra feature at the time… do you know if it’s removable?
Not the one from novacustom (see attached). I believe they usually are though, or atleast should be.
:scream:
I had a fantasy of buying a Starlabs enclosure (they sell parts too) and stuffing my system into that. Would that be technically possible?
No, keep the topic grounded and specific to Qubes OS.
Well, if I could do that that machine would still be running Qubes OS. But yes, I do get your point. Sorry.
Clear the discrepancy, you either are or not.
done
The trackpad on the V56 with Qubes has been a horrible experience for me. Laggy and imprecise.
