Notifications - no longer working in Qubes 4.3 - Debian 13 template - ProtonVPN not minimizing to icon
I was looking for info on an issue with Notifications of ProtonVPN app
I did notice a thread about notification errors related to bluetooth - this seems different
Notification is no longer working in QuBes-4.3 and Debian 13 xfce template
it was fine in qubes-4.2 with Debian 12
it is failing with this error:
$ protonvpn-app
Unrecognized value "gl-disable". Try GDK_DEBUG=help
Unrecognized value "vulkan-disable". Try GDK_DEBUG=help
2026-01-30T11:18:42.575418+00:00 | proton.vpn.core.connection:508 | INFO | CONN:STATE_CHANGED | Disconnected (initial state)
2026-01-30T11:18:42.878217+00:00 | proton.vpn.app.gtk.app:56 | INFO | APP:PROCESS_START | self=<app.App object at 0x794574914d40 (proton+vpn+app+gtk+app+App at 0x1b183980)>
2026-01-30T11:18:42.984458+00:00 | proton.vpn.app.gtk.widgets.main.tray_indicator:122 | WARNING | Tray icon enabled on an unsupported Desktop Environment
2026-01-30T11:18:42.986423+00:00 | proton.vpn.app.gtk.widgets.main.tray_icon:264 | WARNING | TRAY_ICON:STATUS_NOTIFIER_WATCHER_REGISTRATION_FAILED | Failed to register to StatusNotifierWatcher
config of notifications in appvm - same as it was in debian12 :
/usr/share/dbus-1/services/org.freedesktop.Notifications.service
[D-BUS Service]
Name=org.freedesktop.Notifications
Exec=/usr/libexec/notification-daemon
Where should the answer be found, please?
I checked forums on XFCE4, and they gave the same config for notifications.
Thanks,
Protonvpn-gnome-desktop need appindicator package to minimize to tray.
hi @KitsuneNoBaka
thanks for the suggestion, but this package is already installed:
$ sudo apt install gnome-shell-extension-appindicator
gnome-shell-extension-appindicator is already the newest version (59-4).
once started, protonvpn-app will minimise to task-bar
if closed, it will remain in background
if you try to start another instance, the instance running will re-surface
(correct behaviour)
it is the notification that is bugged now
Cheers
p.s.: i did use the correct spelling - minimised
No solution but I just want to validate that I am also experiencing this issue using Fedora 43. I had to rebuild sys-vpn and not enable “start app minimized” in order to have access to the protonvpn app.
Not sure if related, but the Profanity XMPP client is also failing to
send notifications, it was working back in QubesOS 4.2, under debian 12
xfce.
Any updates on this?
Did this worked out for you? I had to roll back from a backup in order to have it in previous state, but having not updated qubes makes me nervous, so I would prefer to find working solution.
Maybe related to this bug Better way to detect the desktop environment · Issue #137 · ProtonVPN/proton-vpn-gtk-app · GitHub
The issue neither has anything to do with QubesOS version upgrade from 4.2 to 4.3 or with debian upgrade from 12 to 13. The issue is actually with Proton VPN version 4.14. The issue was not there in 4.13
I can’t repor the bug on their github forum because when I choose to report a bug they redirect me to Proton VPN support page on their website.
Note: not a dev, this is my partial understanding based on some reading
ProtonVPN 4.13 → 4.14 migrated from GTK3 to GTK4
but AyatanaIndicators’ GTK4 support removed legacy XEmbed fallback, which is what allowed the tray indicator in QubesOS.
GTK4 only supports StatusNotifier, which does not go through QubesOS’s compartimentalization.
See also: RFC: Remove appindicator (system tray) support · Issue #192 · transmission-remote-gtk/transmission-remote-gtk · GitHub, Lark-Gtk | lark-for-linux
Is there anything we can do about this? Or is this just a fact of life we have to accept?
I used “dnf downgrade proton-vpn-gtk-app” until I got back to noarch 4.13.0-1.fc43, and the systray is working again. Which demonstrates the issue is with ProtonVPN 4.14 not with Qubes 4.3, Fedora 43, or Debian 13.
I would expect that there’s nothing to do until QubesOS provides a notification proxy over dbus.
GTK4 will sowly replace GTK3 so this is likely to become a bigger problem over time.
Looking quickly around there doesn’t seem to be any github issue opened - I don’t have an account, so if someone can go ahead and open one…
https://github.com/QubesOS/qubes-issues/issues/10649
While I await on this issue to be resolved
I created a workspace in XFCE (admin) and i move the protonvpn apps there
out of sight and available when needed.
Still no solution on this issue?
i might not be what we hoped for - but there were updates to ProtonVpn App
Proton seems to have removed the icon and quick connection option with it - thus, the app no longer ‘minimises’ as it previously did.
currently i am using protonvpn app to route all my traffic with a window always open in one of the virtual desktops.
I hope it clarifies the situation
Ciao
Yes, I accidentally updated my VPN qube and I don’t see the minimize option at all anymore.
the ProtonVPN app is working fine - but requires the window to be available - you can not just close as it possible previously.
XFCE allows for multiple virtual desktops - very useful to manage different workflows
