Hi, I am running Qubes 4.3 and template Fedora 42.
I install Jami in a Qube and sign in to my PBX.
I place a call to Jami and no notification shows up on the screen (except inside Jami, so if it is in the background I won’t get any indication a phonecall is coming in).
But! ![]()
If I start xfce4-notifyd manually then a notification shows up!
So I tried to find out how to start xfce4-notifyd inside the Qubes I use for Jami but I ran into troubles there.
I can see in journalctl the following messages
May 07 10:30:40 disp7592 dbus-broker-launch[769]: Service file '/usr/share/dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
May 07 10:30:40 disp7592 dbus-broker-launch[769]: Service file '/usr/share/dbus-1/services/org.xfce.xfce4-notifyd.Notifyd.service' is not named after the D-Bus name 'org.xfce.Notifyd'.
Which as far as I understand is systemd trying to create a service for xfce4-notifyd but no such serivice shows up (and the message is normal actually since it is a user systemd service and not a system service, d-bus makes an exception for this mismatch in names for user services).
So I tried to start a notify daemon through a .desktop file in .configure/autostart but no dice there either, I placed the following in the .desktop file
[Desktop Entry]
Type=Application
Name=xfce4-notifyd
Exec=/usr/lib64/xfce4/notifyd/xfce4-notifyd
OnlyShowIn=XFCE
NoDisplay=true
StartupNotify=false
Terminal=false
Hidden=false
but still no notify daemon is started.
Any ideas on how I can get Jami to show notifications?
