hello,
i have a file in the Qube:WORK, and i want to have it Qube:USB, to drop it to the USB stick
I guess there is more than one way to do it. Which one could you recommend?
Thanks
hello,
Thanks
Hello
You can use graphical tool from some file explorer - right click on the
file and select move to another qube, or similar, from drop down menu.
Or open a terminal in the qube, cd to the directory where the file is,
and use qvm-move
Which you use depends on your working practices.
