Hi guys, i bought a Thinkpad x1 carbon 8 yesterday.
I can see it on the Hardware Compatability List (everything is fine on the report) but nothing can run. Usually the message is “Sys-net: Non-endpoint PCI devices cannot be assigned to guests”.
** I can open Firefox, File manager in qube Vault, but nothing work for other qube **
So i’ve tried everything on PCI troubleshooting but nothing change.
I also don’t see any internet connection and when I tried to add wifi connection in Network, everything is disabled.
In the sys-net VM, in a terminal what is the output of the lspci , uname -a and ip a commands? No I can not open the Terminal in Sys-net VM because of the same error “Non-endpoint PCI device…guests”
@Qwerty1111 somehow you ended up assigning all your PCI devices to the ‘personal’ qube. That’s also why the other qubes (e.g. sys-net) can’t use the PCI devices.
in the settings of ‘personal’ go to ‘Devices’ and move everything from ‘Selected’ to ‘Available’.
in the settings for ‘sys-net’ also go to ‘Devices’ and make sure only ‘Network Controller: Intel Corporation’ and ‘Ethernet controller: Intel Corporation’ are assigned.
The HCL report also clearly states that the reporter had to upgrade the kernel to get Wifi to work.
