What kernel version do you have installed in fedora-35 template (or what template did you try)?
Yes I used fedora-35
These kernels are installed and I tried all of them currently using the 5.16.5 one
Iâm out of ideas for now.
I can suggest you to change the topic name to âIntel Wi-Fi 6E AX210 firmware doesnât workâ or something so someone who has the same Wi-Fi adapter can notice your thread and maybe give advice.
thank you very much for your help, learned much from you
Will change the title and if no one else could help me, will buy a USB wifi dongle I guess
Wrong topic, sorry
In case someone encounters this Problem as well:
I could not find out how to make my onboard wifi work (Kille(r) Wi-Fi 6E AX1675x 160MHz Wireless Network Adapter (210NGW))
But I have bought now a Wifi Dongle for that (BrosTrend AC1200 2nd Version) which is also confirmed working on most Linux distros.
What do you think happend when plugging in the device?
Right sys-net was not recognizing it
So the solution for that was fairly easy:
- Setup USB Qube and pass your USB controller to it. If you have multiple only the one who is dealing with the hub you want to use for the dongle should be enough.(was not automaticly done for me, bc of built in keyboard).
- Update the TemplateVM to get all latest drivers.
- Starting the USB Qube and then passing the Wifi Dongle to sys-net.
- VoilĂĄ! The Wifi Dongle is selectable and usable.
