No VM other than Dom0 is running!
Bonjour!
Today (16 February 2026), I updated my Qubes, and after the update, all running VMs were shut down on their on. Now, whenever I try to start any VM, it does not start. Additionally, when I try to open the settings of any VM, I get the following error:
Value Error: Invalid literal for Int () with base 10: 92274688B at line 33 of file/usr/bin/qubes-vm-settings
Any guidance?
Can you post details of that error message?
Do you see also similar error in sudo journalctl -u qubesd output?
This is the output of sudo journalctl -u qubesd :
qubesd.service: start start operation timed out. Terminating.
qubesd.service: Failed with result 'timeout'.
qubesd.service: Unit process 1931 (lvm) remains running after unit stopped.
Failed to start qubesd.service - Qubes OS daemon.
qubesd.service: Scheduled restart job, restart counter is at 1.
qubesd.service: Found left-over process 1931 (lvm) in control group while starting unit. Ignoring.
qubesd.service: This usually indicates unclean termination of a previous run, or service  implementation deficiencies.
qubesd.service: Found left-over process 2976 (lvm) in control group while starting unit. Ignoring.
Uh, start timeout is bad. And lvm that remains running also is not good (it should be short call, should not remain running after qubesd stops). I guess something about LVM itself went wrong. Can you check just sudo journalctl about that time if you seem some LVM-related errors (or generally some other errors before that start timeout)? Maybe something from the kernel about device-mapper (“dm” in short)?
I experienced the same issue but it solved eventually so I’ve to edit this post multiple times. Here is the summary:
Qubes Manager was not running. When I started it from Qubes menu, after clicking on any VM’s settings it crashes.
When I tried to open VM settings from Qubes Menu it gives the following error:
ValueError: Invalid literal for int() with base 10:
'100663296B'
at line 33
of file /usr/bin/qubes-vm-settings.
The output of sudo journalctl -u qubesd was this:
qubesd.service: start operation timed out. Terminating.
qubesd.service: Unit process 1976 (lvm) remains running after unit stopped.
qubesd.service. Found left-over process 1976 (lvm) in control group wile restarting unit. Ignoring.
qubes.service: This usually indicates unclean termination of a previous run, or service implement
Starting qubesd.service - Qubes OS daemon...
Started qubesd.service - Qubes OS daemon.
All the VMs in Qubes Manager were showing 0.0 MiB Disk Usage
I checked journalctl for errors and the following error is there for all VMs
ERROR: vm.sys-net Start failed: Logical Volume "vm-sys-net-private-snap" already exists in volu.....
I tried to remove this snap volume but again got error:
sudo lvremove qubes_dom0/vm-sys-net-private-snap
Check of pool qubes_dom0/vm-pool failed (status:64). Manual repair required!
Failed to update thin pool qubes_dom0/vm-pool.
Then I tried to repair the thin pool but again got error:
sudo lvconvert --repair qubes_dom0/vm-pool
Transaction id 1999 from pool "qubes_dom0/vm-pool" does not match repaired transaction id 1998 from /dev/qubes_dom0/lvol0_pmspare.
Then I followed @unman 's solution here to take backup and then change transaction id.
sudo vgcfgbackup qubes_dom0 -f /home/user/VG_backup
Edited the new file, at the section under logical_volumes->vm-pool->segment1
changed the transaction_id to 1998.
Saved the edited file.
Restored the edited data back in:
sudo vgcfgrestore qubes_dom0 -f /home/user/VG_backup
but it failed
Then used --force to restore it again and it workd
sudo vgcfgrestore qubes_dom0 -f /home/user/VG_backup --force
Activated the edited volume:
sudo lvchange -ay qubes_dom0
It took many minutes but finally it worked. Now everything is working fine. Many thanks to @unman
Something went wrong during pre-reboot dist upgrade. Qubesd timeouted, stuck lvm processes. Did sudo lvconvert --repair qubes_dom0/vm-pool, rebooted, qubesd running, proceeding into post-reboot stages. Thank you marcos-morar.
Thank you! Got me recovered!
