Hello so, i just tired to setup a lan ethernet setup but fail so i want to get back to my setting but i cant change this ti false:
I did before true but i cant change it back, what should i do?
hi,
the messages tells you that the setting can not be changed because some running qubes are using sys-usb as a network provider. Shutdown all qubes using sys-usb, and you should be able to modify sys-usb (you may need to stop sys-usb as well).
