No network on fresh qubes install
When i try to start sys-net or sys-firewall i get unable to reset pci device no flr, pm reset or bus reset available. Im on desktop and connected via ethernet to a router repeater
In sys-net settings, try this
" You can also configure strict reset directly from the Qubes interface by following these steps:
  1. Go to the sys-net VM settings
  2. Go to Devices
  3. Make sure the device is in the right field
  4. Click “Configure strict reset for PCI devices”
  5. Select the device, click OK and apply
    PCI troubleshooting — Qubes OS Documentation
This unfourtunately doesnt do anything to help
In what way?
Do you mean you get exactly the same error?
What device(s) do you have attached?
I doubt that the router has any bearing on this - you could confirm this
by unplugging the cable and attempting to start sys-net. (The
sys-firewall error is because to start that you need to start
sys-net, and that qube is throwing the error.)
Same error and i already tried starting sys-net with it unplugged. I have ethernet device attached to sys-net
