It worked!! Finally i can use Qubes without problems. Thank you so much for you help, appreciate it!
Glad it works now!
This is strange that the chain is empty, it seems that the NetworkManager hook is not working properly for some reason (maybe a timing issue).
So save the command somewhere and use it if this happens again.
Also, you should probably remove no-strict-reset and permissive from your pci attachment to sys-net for security reasons.
Use these commands when sys-net is turned off:
qvm-pci detach sys-net dom0:<pci slot>
qvm-pci attach --persistent sys-net dom0:<pci slot>
Yes, i saved. i started my Desktop right now and the problem just happened again, i executed the command and it back to work. I think that this will back everytime i reboot the machine
Ok, removed here. Thanks
