Hi everybody,
I am a complete newbie when it comes to Qubes.
I currently have Qubes installed on my Macbook Pro 11.2 (Quad-Core Intel Core i7, 8GB memory) on separate partitions in parallel with other Linux operating systems and Big Sur on the same hardware (SSD). The installation went without any problems.
After booting the system, the network icon in the upper right corner of the taskbar is red. When I hover the mouse over it, the text “No network connection” appears.
The information from [Networking basics on qubes] seemed promising, but the problem is that without an internet connection I can’t download broadcom-sta-dkms and all the dependencies directly.
So I downloaded the package on another computer, but when I tried to install it, there were a lot of dependencies on other modules, which in turn depend on other modules. So in a few words, no success.
Here is a summary of the primarily relevant data from my point of view:
- Macbook Pro 11.2 (Quad-Core Intel Core i7, 8GB memory)
- Qubes OS release 4.1.1 (R4.1)
- Default Template: debian-11
Output of lspci [dom0]:
00:00.0 Host bridge: Intel Corporation Crystal Well DRAM Controller (rev 08)
00:01.0 PCI bridge: Intel Corporation Crystal Well PCI Express x16 Controller (rev 08)
00:02.0 VGA compatible controller: Intel Corporation Crystal Well Integrated Graphics Controller (rev 08)
00:03.0 Audio device: Intel Corporation Crystal Well HD Audio Controller (rev 08)
00:14.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB xHCI (rev 05)
00:16.0 Communication controller: Intel Corporation 8 Series/C220 Series Chipset Family MEI Controller #1 (rev 04)
00:1b.0 Audio device: Intel Corporation 8 Series/C220 Series Chipset High Definition Audio Controller (rev 05)
00:1c.0 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #1 (rev d5)
00:1c.2 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #3 (rev d5)
00:1c.3 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #4 (rev d5)
00:1c.4 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #5 (rev d5)
00:1f.0 ISA bridge: Intel Corporation HM87 Express LPC Controller (rev 05)
00:1f.3 SMBus: Intel Corporation 8 Series/C220 Series Chipset Family SMBus Controller (rev 05)
02:00.0 Network controller: Broadcom Inc. and subsidiaries BCM4360 802.11ac Wireless Network Adapter (rev 03)
03:00.0 Multimedia controller: Broadcom Inc. and subsidiaries 720p FaceTime HD Camera
04:00.0 Non-Volatile memory controller: Silicon Motion, Inc. SM2262/SM2262EN SSD Controller (rev 03)
05:00.0 PCI bridge: Intel Corporation DSL5520 Thunderbolt 2 Bridge [Falcon Ridge 4C 2013]
06:00.0 PCI bridge: Intel Corporation DSL5520 Thunderbolt 2 Bridge [Falcon Ridge 4C 2013]
06:03.0 PCI bridge: Intel Corporation DSL5520 Thunderbolt 2 Bridge [Falcon Ridge 4C 2013]
06:04.0 PCI bridge: Intel Corporation DSL5520 Thunderbolt 2 Bridge [Falcon Ridge 4C 2013]
06:05.0 PCI bridge: Intel Corporation DSL5520 Thunderbolt 2 Bridge [Falcon Ridge 4C 2013]
06:06.0 PCI bridge: Intel Corporation DSL5520 Thunderbolt 2 Bridge [Falcon Ridge 4C 2013]
07:00.0 System peripheral: Intel Corporation DSL5520 Thunderbolt 2 NHI [Falcon Ridge 4C 2013]
Output of lsusb [dom0]:
Bus 002 Device 002: ID 05ac:8406 Apple, Inc. Internal Memory Card Reader
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 006: ID 05ac:8289 Apple, Inc. Bluetooth Host Controller
Bus 001 Device 002: ID 0a5c:4500 Broadcom Corp. BCM2046B1 USB 2.0 Hub (part of BCM2046 Bluetooth)
Bus 001 Device 003: ID 05ac:0263 Apple, Inc. Apple Internal Keyboard / Trackpad (MacBook Retina)
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Output of ifconfig [sys-firewall]:
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.138.4.137 netmask 255.255.255.255 broadcast 10.255.255.255
inet6 fe80::216:3eff:fe5e:6c00 prefixlen 64 scopeid 0x20
ether 00:16:3e:5e:6c:00 txqueuelen 1000 (Ethernet)
RX packets 30 bytes 2202 (2.1 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 53 bytes 4006 (3.9 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10
loop txqueuelen 1000 (Local Loopback)
RX packets 12 bytes 632 (632.0 B)
TX packets 12 bytes 632 (632.0 B)
vif4.0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.138.4.137 netmask 255.255.255.255 broadcast 0.0.0.0
inet6 fe80::fcff:ffff:feff:ffff prefixlen 64 scopeid 0x20
ether fe:ff:ff:ff:ff:ff txqueuelen 32 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 12 bytes 936 (936.0 B)
Output of ifconfig [sys-net]:
vif3.0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.138.27.206 netmask 255.255.255.255 broadcast 0.0.0.0
RX packets 53 bytes 3264 (3.1 KiB)
TX packets 31 bytes 2692 (2.6 KiB)
I will provide all the information that could help to find a solution.
An Internet connection is important: Either wired or WiFi.
Can someone please, please help?
Thanks a lot!
