No Internet Connection or ICON
Hello Guys, i have installed my first QubesOS on my laptop. i have only whonix gateway and workstation installed. Now i need help for the configuration, i have watched many youtube videos for the internet connection but nobody helped me.
Do i need a ‘sys-net’ qube and when yes;
any manuals for this?
what template do i need?
thanks for help.
best regards,
kencho
SOLUTION: CHOOSE DEBIAN AND FEDORA ON THE INSTALLATION CONFIG
You have to manually press yes as this is the requirement to connect your Wi-Fi
Where do you think I should go ‘yes’?
Maybe he meant selecting Create default system qubes during the first boot configuration:
If you type qvm-ls | grep sys-net in a dom0 terminal, do you see any results?
You need to have either debian or fedora template to create sys-net.
Crete new qube with type AppVM, template debian/fedora, networking none.
Open Qubes Settings for this qube in Advanced tab:
Deselect “Include in Memory balancing”
Set initial memory to 400 MB
Select “Provides network”
Select Virtualization mode to HVM
In Devices tab select your network adapter.
no, i see nothing.
okay i must reinstall now and choose fedora and debian…
You can either reinstall, making sure to select Create default system qubes and at least a template at the first boot after installation, or you can create the qubes manually without reinstalling.
And here it says how to do it: Fedora, Debian. But indeed, for new users, it’s recommended to use the default configuration during the installation.
thanks i have reinstalled now and choosen fedora and debian. now i have connection!! THANKS
