No installer on Asrock X370 Taichi
here is my hardware:
-Asrock X370 taichi
-Ryzen 1700
-AMD RX 5700XT
So I tried getting the installer to work but i never got further than Xen (trying) to boot. No error seems to show up. I thought Qubes would work well with my system seeing this HCL:
https://groups.google.com/forum/#!msg/qubes-users/8s8DrjMZWBE/yciubtb_BQAJ
But I was wrong, I guess I have to wait for the 4.1 but this is frustrating. If anyone with a similar setup managed to find the magic button I would very thankful.
KileXt
-AMD RX 5700XT
This is your likely answer. They do work, but require kernel-latest,
which is not in the ISO. Could you install to your disk on another
machine or borrow a GPU?
Thanks very much ! I do have another gpu, it’s an Rx 380, so you think I could get away with installing using this older card, upgrading and then swapping them ?
Well I just swapped the card and still blank so I don’t know. I will try on an old machine I got around and put the disk in my main. Maybe that will do.
You may try this:
Hi, thanks very much for your link, it solved my problem ! I just needed to remove the lines:
noexitboot=1
mapbs=1
The GPU caused no issue at all and Qubes works flawlessly now.
Thanks again,
KileXt
I’m happy it lead you into the right direction !
Have fun with Qubes OS :slight_smile:
