Hello,
Fresh install, 4.1, I have no connection.
Only Whonix does connect using sys-whonix.
Any other qubes, with sys-firewall or sys-net does not connect.
These qubes can ping 8.8.8.8 though …
I’ve tried setting up manually (IP, /24, gateway, DNS) to no avail.
As it is a fresh install, all qubes are standards pre-confirgured.
So … disposable whonix, anon-whonix, personnal, work, etc …
All qubes using sys-whonix does Browse (firefox access the net)
All qubes using sys-firewall does not. I’ve changed to sys-net, still not.
BUT despite they can’t browse the net, they can ping the 8.8.8.8.
When I change (say “personnal”) to sys-whonix, it can browse.
I don’t see the point, since it already can ping one, it sure can ping others.
DNS 9.9.9.9 is same as 8.8.8.8 except the 9 blocks malicious while the 8 does not
Ping 9.9.9.9 works (not surprised) ping 167.172.100.80 works as well
user@personal: dig forum.qubes-os.org
<> dig 9.16.22-debian <> forum.qubes-os.org
global option +cmd
connectoion timed out; no servers could be reached
failed
user@personal: dig forum.qubes-os.org@8.8.8.8
<> dig 9.16.22-debian <> forum.qubes-os.org@8.8.8.8
global option +cmd
This tells us that the problem is with DNS handling in clear net
connections.
We know that you have a working internet connection, as the Tor
connection works.
It’s possible that your connection does not provide you with a DNS
server address.
In sys-net, check the contents of /etc/resolv.conf, which should be
generated by network manager and show the IP address(es) of DNS server
provided by your ISP. sudo nft list table nat will show you the PR-QBS chain, using dnat to
change 10.139.1.X DNS traffic to those provided DNS server IPs.
Look at those and report back.
