When I connect a Qube called InternetQube to the Firewall Qube, sys-firewall, I can’t get any connection. I am not sure why.
I have a wireguard qube “sys-wireguard” before the firewall.
I also can’t get a connection if I connect the InternetQube directly to “sys-wireguard”
sys-wireguard whitelists only certain IPs, but the wireguard connection should send everything to those IPs
When I connect another network Qube “sys-openvpn” to sys-firewall which connects to sys-wireguard (which connects to sys-net), if I then connect InternetQube to sys-openvpn and connect to an openvpn address, then I can use InternetQube.
None of this makes sense to me. sys-wireguard should connect through UDP through my sys-net. The sys-firewall that is there is mostly so I can pause the firewall to stop all connections if I want and I can route everything to sys-firewall. I should be able to connect to sys-firewall and open up a webpage. But I can’t.
What is going on?
