Hey!
I backuped my system and restored it in Qubes 4.1, so far, so good.
But I can not adjust display brightness. It just shows no effect.
Best regards
qun
Hey!
Best regards
qun
Do somebody has an idea here?
Full brightness at night is VERY creepy
The problem has something to do with the Nvidia-Optimus-Mode. If i start the Laptop in this mode (just as always, also in Qubes 4.0), I can not adjust the brightness. If i change it in bios to internal grafic card, it works. BUT if I restart the laptop it changes automatically to Nvidia-Optimus. So I must every time go to bios when I (re)start the Laptop and set internal card.
Somebody an idea?
Perhaps you could search on Fedora forums, since Qubes dom0 uses Fedora-32.
hmm… ok, so you mean, it’s not a special Qubes problem.
In similar cases there is a workaround. Run in the terminal (Dom0)
xrandr -q
in order to check the primary display. Once you have it, run:
xrandr --output LVDS-1 --brightness 0.5
where LVDS-1 is the primary screen and brightness value is at 50% (accordingly 0.6 equals 60%).
