Hi!
I’m setting up sys-audio qube, I’ve followed the instructions mentioned in many sys-audio related discussions.
However I am having internal audio driver issues. There’s no actual hardware sound output at all from internal speakers but if I attach bluetooth headphones they work.
speaker-test -c 2 -t wav in sys-audio is completely silent.
My laptop is Lenovo ThinkPad X1 Extreme Gen-1
Audio device is 00:1f.3 Audio device [0403]: Intel Corporation Cannon Lake PCH cAVS [8086:a348] (rev 10)
Audio card don’t get loaded with just --option no-strict-reset=True I had to add --option permissive=True to load the card
but there is no sound from the hardware
In alsamixer Speaker channel stuck at 00 there are no bars and arrows do nothing.
amixer controls | grep -i speaker gave no output
Tried overriding every unconnected pin to Internal speaker using hdajackretask with no luck
/proc/asound/card*/codec#* is empty there is no codec dump
dmesg is giving this output:
sudo dmesg | grep -E 'snd|sof|audio|hda'
[ 0.177273] Performance Events: unsupported p6 CPU model 158 no PMU driver, software events only.
[ 3.931432] snd_hda_intel 0000:00:07.0: spurious response 0x0:0x2, last cmd=0x000000
[ 4.932600] snd_hda_intel 0000:00:07.0: azx_get_response timeout, switching to polling mode: last cmd=0x000f0000
[ 5.934150] snd_hda_intel 0000:00:07.0: No response from codec, disabling MSI: last cmd=0x000f0000
[ 6.937157] snd_hda_intel 0000:00:07.0: Codec #0 probe error; disabling it...
[ 6.937189] snd_hda_intel 0000:00:07.0: no codecs initialized
I’ve also installed firmware-sof-signed in sys-audio template but no luck again.
Is there a solution at all?
