layout:
'hcl'
type:
'Notebook'
hvm:
'yes'
iommu:
'yes'
slat:
'yes'
tpm:
'2.0'
remap:
'yes'
brand: |
Notebook
model: |
novacustom-v560tu
bios: |
Dasharo Nitrokey-v0.2.1-3102-g5f612de-dirty
cpu: |
Intel(R) Core(TM) Ultra 5 125H
cpu-short: |
FIXME
chipset: |
Intel Corporation Device [8086:7d14] (rev 04)
chipset-short: |
FIXME
gpu: |
Intel Corporation Meteor Lake-P [Intel Arc Graphics] [8086:7d55] (rev 08) (prog-if 00 [VGA controller])
gpu-short: |
FIXME
network: |
Intel Corporation Meteor Lake-P Gaussian & Neural-Network Accelerator [8086:7e4c] (rev 20)
Intel Corporation Device [8086:550a] (rev 20)
Intel Corporation Wi-Fi 7(802.11be) AX1775*/AX1790*/BE20*/BE401/BE1750* 2x2 [8086:272b] (rev 1a)
memory: |
65177
scsi: |
nvme: |
S6Z1NF0L105892V Samsung SSD 990 PRO 1TB 8B2QJXD7
usb: |
3
certified:
'yes'
versions:
- works:
'FIXME:yes|no|partial'
qubes: |
R4.3.2
xen: |
4.19.6
kernel: |
7.2.11-1
remark: |
FIXME
credit: |
FIXAUTHOR
link: |
FIXLINK
Remarks
The initial Qubes OS install was working fine - as expected from a ‘certified’ device.
However my NitroPad V56 (NovaCustom V560TU, Meteor Lake iGPU) with Qubes OS 4.3.2, the GPU hangs about ~12 minutes after resuming from S3 suspend. The GuC stops responding, i915 resets the GPU, and the screen freezes for about 30s, then recovers. It happened twice, both times after a resume.
Workaround (so far no hang since):
Add this to GRUB_CMDLINE_LINUX in dom0’s /etc/default/grub, then rebuild GRUB:
i915.enable_psr=0 i915.enable_panel_replay=0
With Heads, /boot must be re-signed after that.
Setup: dom0 kernel 7.2.11-1.qubes.fc41, stock i915, Xorg modesetting, mem_sleep = deep (S3). Firmware is Nitrokey’s Dasharo + Heads build (Nitrokey-v0.2.1-3102-g5f612de-dirty).
Related firmware bug: the VBT declares a second internal eDP panel on DDI B that doesn’t exist. That produces an i915 vdd_wakeref warning at every boot, and possibly the raw-wakerefs=1 wakelocks=1 on cleanup warning at every suspend. Dasharo already tracks this one.
Upstream reports:
- Dasharo: phantom eDP in the VBT: V560TU 0.9.0->1.0.0: WARNING: CPU: 3 PID: 360 at drivers/gpu/drm/i915/display/intel_pps.c:755 intel_pps_vdd_on_unlocked+0x32b/0x340 [i915] · Issue #1617 · Dasharo/dasharo-issues · GitHub
- Dasharo: GPU hang after S3 resume: NitroPad V56 (V560TU): i915 GPU hang (GuC stops responding) · Issue #1954 · Dasharo/dasharo-issues · GitHub
- Nitrokey forum (no reply yet): NitroPad V56: phantom second eDP in the VBT + GPU hang after S3 resume - NitroPad, NitroPC - Nitrokey Support
Questions for Qubes users and devs:
- Does anyone else see this on a V54/V56 or another Meteor Lake laptop? Which firmware (Dasharo UEFI or Heads) and which kernel?
- Since the V56 is on the Qubes certified list, should this workaround go into the HCL/certification notes until it’s fixed upstream?
Full logs and the decoded VBT are in the Dasharo issues.
