Hello Qubes community,
First week at Qubes os, and I’m new to Linux as well (another Windows and macOS refugee).
I have some general questions while reading, learning and trying Qubes os.
dom0
Total disk usage try icon shows volumes (Linux kernal - varlibqubes - vm-pool), so, these 3 were created by LVM?, any documentations about them?
Under vm-pool showing data and metadata, data is a what, partition or folder ? that has most of storage space !!, can I create a folder in that space to backup app qube to? for now, the back is inside each app qube backup folder !!! doesn’t look right for me. deleting one by mistake or whatsoever.
Can I create another partition to show under folder manager " as of now, I have only File System, and another one is like Hard drive type/model/serial, double click and nothing.
Is there a GUI app like disk manager on Windows that I can use to it explore the disk structure, many commands I tried to learn lvm structure which I got it on a linux system (demo online), on Qubes os , I was lost kinda with all printed data, like what many pools are( pool1, pool2, pool3 …etc) and nested things which are not clear. (couldn’t find any in documentations).
Clipboard
Sometime I copy some text then I don’t need to paste it, how to clear it as it keeps showing in the try icon? automatically after a minute or so even better.
sys-usb
sys-usb size is showing 200mb+ at updates, after restart is 1.8 then moved all the way up to 86mb??
Why it has an ip address?
Template update
Reading details of an update, does the update of a template update the packges as well, let’s say the default packages (applications) that come with each template (debian, fedora, whonix)
App qube settings
There is a “services” tab, Where I can read and learn more about them all?
Audio
I plug my headphones and I can listen to any audio from any App qube right away, if I check App qube settings, the audio device is not attached, so, it is by default in Qubes os design ? then if you need to dedicate it to a specific app qube you can do so ("from settings - devices - “add audio device to the app qube”)?!
App qube
I opened gpart GUI from one of the app qube just to have an idea, I have noticed a warning next to EFI xvda1 partition “unable to detect file system, some possibilities are …” is it normal ?
NOTE: next release of Qubes OS is so exciting, it would solve many things I was working on it manually and searching for it, you may have a look at Qubes OS 4.3 release note
https://qubes-doc--1504.org.readthedocs.build/en/1504/developer/releases/4_3/release-notes.html
