I am fairly new to Linux so the solution is probably pretty basic, but I could not find anything concerning this anywhere.
I was trying to make my WIFI persistent inside my disposable sys-net qube by copying the nmconnection file to the /rw/config/NM-system-connections directory of my fedora-dvm template qube. For context I tried copying it 2 different ways
by using the qvm-copy-to-vm copy function of qubes
by creating the file with nano and copying the contents
and I ran into the same Issue with both Methods. Instead of using the nmconnection file a new connection file with the schema [wifi name][random uuid].nmconnection gets created and used instead.
I tried setting the owner of the file using chown root:root and changed it’s permissions to u=rw using chmod insinde the dvm template but the same thing kept happening.
How do I get the the qube to accept configuration files I created?
I did get it working by setting my dvm template qube to hvm and connecting to the WIFI inside the dvm directly but I would rather get it to work by copying the file.
Your problem is that interface name in disposable template and disposable qube have different names wls6 and wls7 so the Network Manager think of them as different connections.
If you have the same wls7 interface name in disposable qube on every start then you can just change interface name in disposable template from wls6 to wls7 and the connection will work in disposable qube.
Another way will be changing the interface name: Network configuration - ArchWiki
Set your connection as you like it in sys-net, and then just copy it to /rw//config/NM-system-connections folder of sys-net’s dvm-template. Shut down dvm-template and restart sys-net. It’s all there.
I had the same problem, however in my case it was caused by wrong file owner and group of the NMconnection file in the disposable template. Looking at output of ls -l both were set as user. Setting them as rootwith sudo chown root:root [wifi name].NM fixed it for me.
Sorry for reviving this old thread, but maybe this will help someone finding this.
