I’m having an unusual issue with Qubes 4,2, that never occurred with 4.1. I’m wondering if anyone else is having this issue, or has ideas on where to look.
Whenever sys-net is restarted, for example by Qubes Update, network manager fails to reconnect.
This does not happen if sys-net is stopped, then started
This does not happen if wifi interface is used (only occurs for wired)
Workarounds:
Stop/Start sys-net (not a good option)
Rebooting PC (not a good option)
Remove patch cable, wait 5 seconds, re-attach patch cable (this works)
Logs show many events like this: dhcp4 (ens6): state changed no lease
After re-attaching patch cable, will see: dhcp4 (ens6): state changed new lease, address=192.168.x.y
sys-net is using fedora-39-xfce for template
This issue occurs on two different PC’s both running 4.2 with wired connections (and does not occur on their wifi connections).
Both are using DHCP, and connecting to different switches.
Has anyone else had this issue?
Any ideas?
