Hi, new to Qubes, I’ve been experimenting with making all the types of Qubes, but I can get networking on only one of my Service qubes but not others, one of my Template qubes but not others, 3 of my Application qubes has it working but not 5 others, I have no idea why.
What settings do I need to check to make networking work?
Welcome to Qubes.
Networking should be automatic if you have the netvm set in a qube.
There’s almost never any need to have templates directly connected to
the network because they use a proxy to get updates. This is covered in
the docs.
So that is where you start. If you have sys-net connected to a network,
and you have a qube with netvm set to sys-net, it should be able to
access that network. Then, a qube with netvm set to sys-firewall should
be able to access…, and so on.
Without a great deal more information it’s difficult to know what
problem you have encountered.
Start off with basic template-based qubes with netvms leading up to
sys-net.
If any dont work, look at the template they are using.
Gather information on what works and what doesnt and fed it back in
detail.
