Hi, I just completed upgrade to Qubes 4.2
I’m having network issues: network work ONLY in sys-net, any other qube has no internet access (maybe a DNS issue?).
I tried to manually run sudo /usr/lib/qubes/qubes-setup-dnat-to-ns in sys-net but the issue persist.
This issue started in STAGE 4, initially probably caused by mirage firewall, that I removed and replaced with sys-firewall (solving the libxenlight issues but not the network issues).
Anyone had the same problem and know how to fix it?
Can you ping IP addresses from sys-firewall?
Try to ping in sys-firewall for a test:
ping 9.9.9.9
ping quad9.com
No, I tried but not work. Ping from sys-net work. From any other qube (including sys-firewall) not work.
Can you post the output of this command in sys-net and sys-firewall?
sudo nft list ruleset
user@sys-net:~$ sudo nft list ruleset
table ip qubes {
set downstream {
type ipv4_addr
set allowed {
type ifname . ipv4_addr
chain prerouting {
type filter hook prerouting priority raw; policy accept;
iifgroup 2 goto antispoof
ip saddr @downstream counter packets 0 bytes 0 drop
chain antispoof {
iifname . ip saddr @allowed accept
chain postrouting {
type nat hook postrouting priority srcnat; policy accept;
oifgroup 2 accept
oif "lo" accept
masquerade
chain input {
type filter hook input priority filter; policy drop;
jump custom-input
ct state invalid counter packets 0 bytes 0 drop
iifgroup 2 udp dport 68 counter packets 0 bytes 0 drop
ct state established,related accept
iifgroup 2 meta l4proto icmp accept
iif "lo" accept
iifgroup 2 counter packets 0 bytes 0 reject with icmp host-prohibited
counter packets 10 bytes 2316
chain forward {
type filter hook forward priority filter; policy accept;
jump custom-forward
oifgroup 2 counter packets 0 bytes 0 drop
chain custom-input {
chain custom-forward {
chain dnat-dns {
type nat hook prerouting priority dstnat; policy accept;
ip daddr 10.139.1.1 udp dport 53 dnat to 192.168.2.1
ip daddr 10.139.1.1 tcp dport 53 dnat to 192.168.2.1
table ip6 qubes {
set downstream {
type ipv6_addr
set allowed {
type ifname . ipv6_addr
chain antispoof {
iifname . ip6 saddr @allowed accept
chain prerouting {
ip6 saddr @downstream counter packets 0 bytes 0 drop
chain postrouting {
oifgroup 2 accept
oif "lo" accept
masquerade
chain _icmpv6 {
meta l4proto != ipv6-icmp counter packets 0 bytes 0 reject with icmpv6 admin-prohibited
icmpv6 type { nd-router-advert, nd-redirect } counter packets 0 bytes 0 drop
accept
chain input {
jump custom-input
iifgroup 2 goto _icmpv6
iif "lo" accept
ip6 saddr fe80::/64 ip6 daddr fe80::/64 udp dport 546 accept
meta l4proto ipv6-icmp accept
chain forward {
jump custom-forward
table ip qubes-firewall {
chain forward {
type filter hook forward priority filter; policy drop;
iifname != "vif*" accept
ip saddr 10.137.0.32 jump qbs-10-137-0-32
chain prerouting {
iifname != "vif*" ip saddr 10.137.0.32 drop
chain postrouting {
type filter hook postrouting priority raw; policy accept;
oifname != "vif*" ip daddr 10.137.0.32 drop
chain qbs-10-137-0-32 {
accept
reject with icmp admin-prohibited
table ip6 qubes-firewall {
chain forward {
chain prerouting {
chain postrouting {
user@sys-firewall:~$ sudo nft list ruleset
table ip qubes {
set downstream {
type ipv4_addr
set allowed {
chain prerouting {
chain antispoof {
chain postrouting {
oifgroup 2 accept
oif "lo" accept
masquerade
chain input {
jump custom-input
iif "lo" accept
chain forward {
jump custom-forward
chain dnat-dns {
ip daddr 10.139.1.1 udp dport 53 dnat to 10.139.1.1
ip daddr 10.139.1.1 tcp dport 53 dnat to 10.139.1.1
ip daddr 10.139.1.2 udp dport 53 dnat to 10.139.1.2
ip daddr 10.139.1.2 tcp dport 53 dnat to 10.139.1.2
table ip6 qubes {
set downstream {
type ipv6_addr
set allowed {
chain antispoof {
chain prerouting {
chain postrouting {
oifgroup 2 accept
oif "lo" accept
masquerade
chain _icmpv6 {
accept
chain input {
jump custom-input
iif "lo" accept
chain forward {
jump custom-forward
chain forward {
ip saddr 10.137.0.38 jump qbs-10-137-0-38
ip saddr 10.137.0.7 jump qbs-10-137-0-7
ip saddr 10.137.0.23 jump qbs-10-137-0-23
ip saddr 10.137.0.31 jump qbs-10-137-0-31
ip saddr 10.137.0.21 jump qbs-10-137-0-21
chain prerouting {
iifname != "vif*" ip saddr { 10.137.0.7, 10.137.0.21, 10.137.0.23, 10.137.0.31, 10.137.0.38 } drop
chain postrouting {
oifname != "vif*" ip daddr { 10.137.0.7, 10.137.0.21, 10.137.0.23, 10.137.0.31, 10.137.0.38 } drop
chain qbs-10-137-0-38 {
accept
chain qbs-10-137-0-7 {
accept
chain qbs-10-137-0-23 {
accept
chain qbs-10-137-0-31 {
accept
chain qbs-10-137-0-21 {
accept
chain forward {
chain prerouting {
chain postrouting {
Did you run sudo nft list ruleset in sys-net when sys-fiwarall was running and connected to sys-net?
For some reason the sys-firewall IP is not present in downstream and allow sets, it should’ve been like this:
table ip qubes {
set downstream {
type ipv4_addr
elements = { 10.137.0.32 }
set allowed {
elements = { "vifX.0" . 10.137.0.32 }
But at the same time sys-fireweall IP is present in `qubes-firewall` forward chain.
Not sure what is broken.
Do you use template updated from Qubes OS 4.1 to Qubes OS 4.2 for sys-net?
Maybe the upgrade failed somewhere.
I'd suggest to install clean Qubes OS 4.2 templates and use them.
Thanks for reply
I fixed by installing fresh debain-12-minimal template for network VMs (with network-related packages).
palainp
December 23, 2023, 1:54pm
8
Now it’s fixed, would you mind to try out again with mirage-firewall? I’m interested to fix any potential issue here. I’m also on up to date 4.2 and I don’t have issues (even with 32Mb memory).
