I’ve spent hours on this and tried every guide. This is the main one:
When I go to select the .conf file I get the error:
Could not create new connection
the vpn plugin failed to import the vpn connection correctly: key file contains line “client” which is not a key-value pair, group, or comment
I also tried running: sudo openvpn update-resolv-conf from the directory its installed in and get: error opening configuration file
We don’t know which version of Qubes you are using, how exactly you created vpn qube, what exactly means that you “didnt find a solution that works” for you on a thread @fsflover referred to, etc…
