Hello!
I’ve only found 1 reddit post about it ,and the solution was deleted. I’d like to create a qube for thunderbird. I’ve thought because i only need the Thunderbird package, i will go with a qube based on a minimal template. Unfortunately by default there is no internet (it is connected to the sys-firewall) on a qube based on a minimal template. How can i make net on a minimal qube?
Thanks any help!
Hi @onequbesuser,
Have you read the documentation yet? The answer is there
Spefically on the distro-specific notes.
Yeah i’ve read the documentation. Which part of it contains what i need? The Distro-specific notes? I can’t really tell which one is needed for me…
I remember having this problem, even after reading the docs… twice.
hint: install qubes-core-agent-networking in the minimal template.
Thanks! It’s not just me at least. It is really not so clear. I’ve read it at least 3 or 4 times to figure out which package is needed for me. I thought these packages were just for making any sys-* type VM based on minimal template. Do i need the the iproute package too or qubes-core-agent-networking is enough?
Haha. Sorry for making you look. If there is anything in the documentation that doesn’t seem clear enough, you can always improve them
