Network broken after in-place upgrade to 4.1 on x230
Continuing the discussion from [qubes-users] Network broken after in-place upgrade to 4.1 on x230:
@badgateway
This could be because of firmware update needed as stated in the link below
If you want to use Qubes 4.1 or newer and the integrated Ethernet port you need to update the firmware to 1.4.
https://docs.nitrokey.com/nitropad/qubes/firmware-update-1.4.html
Hi, thanks for your response!
This was exactly my problem. I just did an upgrade of my HEADS Firmware, and now ethernet works again :slight_smile:
Maybe this is worth a mention in the upgrade notes somewhere?
Kind regards and again, thank you very much!
