hello dear qubes community, I am having a question about netVM and ClockVM.
When viewing the global settings, netVM is on sys-firewall, and ClockVM is on sys-net, both by default. Should I leave it like that?
one post about ClockVM that I have read was the following:
I’ve been able to get a quiet Qubes machine by:
Setting ClockVM to ‘None’ in Global Settings. This prevents NTP traffic in the chosen qube.
just as an example. i am thankful for any input about this.
What would happen if I set netVM or ClockVM to sys-whonix?
what i wanted to know: is my fingerprint different if i tweak it to (none) in comparison to someone who left it on default? i don’t wanna increase my fingerprint.
you should randomize your hostname (to DESKTOP-[random character] ) as the default one increase fingerprint
good point. but the host name is the same unique name for every vm that I use. i want to have separate identities for each of my vms. isn’t that bad then?
yes, you can attach your network card to sys-firewall, but security is weaken then, so qubes dev add [1] sys-net so it have better compartmentalization → better security
