Need some help with setting up mullvad vpn
I need some help with setting up mullvad based on this guide
I was able to get to step 5 after i set up my vpn once i started adding the firewall scripts and the auto start after that i tried to go into the appvm that was using my sys-vpn for networking and went to the mullvad website and it said that i wasnt connected to mullvad anymore if someone could give me a hand would appreciate it. p.s I’m trying to able to connect to tor then my vpn
Are you using Qubes OS 4.1 or 4.2?
The guide is for Qubes OS 4.1.
For Qubes OS 4.2 you need to use nftables instead of iptables.
Oh didn’t know I’m using 4.2 where can I find some examples for nftables that I would need to use I’m new to qubes and Linux
Here is an example for wireguard, you can get the example nftables rules from there:
You can also try Qubes-vpn-support:
