Hello. At this moment, I use QubesOS 4.1 RC2 without any updates in dom0.
Few days ago I used RC2 with updates, but I have some problems after latest updates. The gui-domain was broken in Windows VM (when I press ALT + F11, window of Windows VM is disappear.
And booting any qube from cd-rom doesn’t work.
I installed RC3, and bug in gui-domain is remain. Booting from cd-rom is working without updates, but after installing updates it’s doesn’t work
I can’t work in Windows without fullscreen-mode, so I return to RC2. All great, but booting from cd-rom doesn’t work. I need to install bsd from cd-rom (for networking) and I need to fix problem without breaking something.
I seen package list on yum.qubes-os.org , but I don’t understand which package controls booting from cd-rom.
So, I need info which packages controls gui-domain and booting from cd-rom to exclude it from upgrade and try to install not latest versions after upgrading other packages.
And I need help with dnf syntax for excluding packages and installing specific version.
Sometimes my English can be broken, I’m sorry.
