Need help with gpu passtrough
  • xen is 4.17.2-8
  • amd 6700 XT
followed this guide and got to this point Create a Gaming HVM
I created a standalone from the standard fedora-38-xfce vm and did
sudo dnf install @base-x gnome-shell
I can start and restart the VM with no issues but I don’t get any display output at all. Sometimes the GPU fans spin up and my monitor flashes (detects something over HDMI).
The only way I can access the VM is over Qubes-Manager → open console in qube (Nothing starts on my primary display anymore)
Then I get a constant loop of error messages and when I login as the user and try to run xrandr or gnome-shell I only get the error message “can’t open display”.
sudo dmesg gives me drm timeout errors.
But I can’t really type anything because my terminal gets flooded with errors.
I don’t know how I should proceed/debug from here. Or if I forgot something (I followed the guide exactly up until the point I marked).
Actually I have no idea what to do after attaching the GPU to the vm. How can I can/should I configure everything after that. I am not even sure why nothing from the vm gets displayed on my primary monitor anymore and if it’s even supposed to do that.
Got it working
