It should be not the same fingerprint, right? Still, Firefox browser and Telegram application are two different access levels, no?
I am definitely not the right person to answer the questions above, but β¦
There are probably packages in fedora and Debian which will handle the AT/SMS for you.
if I wanted to put a bug or tracer on someone, the firmware of a network device seems ideal. It can see everything going through it, and anything you let it see on your machine, and for LTE you need some exotic RF equipment to even hope to see what it is sending itself.
Need some advice. Tried to test AT commands usage but it seems sys-net terminal doesnβt recognize them. Says itβs unknown bash command. Maybe it needs some special command to enter AT commands mode or installation of some special package. Read many articles but they seem are all for old modems or have not enough info for correct understanding. Can you check this one and say if this manual suitable for Qubes? Didnβt try it because there is SSH so Iβm not sure if itβs relevant for Qubes. Maybe here is a person who knows the correct way to enable AT commands in Qubes? What additional packages needed, etc.
Also tried to use cloned sys-net for this test, as was suggested before. Unchecked βprovides networkβ and βstart during bootβ. When I started qube itself it couldnβt even start. There was only a constantly spinning circle in Qubes Domains. Somehow each time when I interacted with this qube (generaly just by watching its qube settings) it always turned mic and dynamic volume on, though it was always turned off by me and I never touched any sound settings after this. Anyway this qube couldnβt start and even didnβt react on βkillβ button so I had to delete it. My guess is that I probably had to stop sys-whonix, sys-firewall and sys-net first, before starting this one, though I still donβt fully understand the logic why.
AT commands works in serial connection only. Some modems provide web based serial terminal, to some you must start serial connection in shell.
Most widelly used serial terminal is minicom.
Search web how to connect to serial port of your modem.
PS: it was 12 years ago when Iβve dealt with modem and AT comnands and done that on router in dd-wrt (and it was βfire&forgetβ) but in linux you could use command screen to establish serial connection to usb device
I installed Screen on my Debian template then followed this manual that I found in the web. Wouldnβt say that I fully understood this all. First I just used sudo dmesg | grep tty command to find that tty number of my modem. Not sure what meant βFind the tty number while you are already connectedβ but instead of example output it gave out completely different output:
[ 8.587464] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[ 8.590563] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
So Iβm stuck on this step 'cause I donβt know tty number of usb and suspect more and more that I chose wrong manual.
Anyway, what was it trying to tell me in this last output?
Nothing.
You found unrelated dmesg entry.
Try with journalctl |grep tty instead
Another way is to run
journalctl -f
and then plug your modem.
The log messages will appear as they are created, and you can press Ctrl-C to stop any new ones from hiding the useful ones.
Tried your method. It gave a lot of text with word βgettyβ.
Tried your method too. Got a lot of text. Copied it to the text file. Searching found only one word βttyβ: user : TTY=pts/0 ; PWD=/home/user ; USER=root ; COMMAND=/usr/bin/journalctl -f
Posting full version:
sudo journalctl -f
ΠΈΡΠ½ 22 03:33:30 sys-net systemd[1]: Stopping user-runtime-dir@0.service - User Runtime Directory /run/user/0...
ΠΈΡΠ½ 22 03:33:30 sys-net systemd[1]: run-user-0.mount: Deactivated successfully.
ΠΈΡΠ½ 22 03:33:30 sys-net systemd[1]: user-runtime-dir@0.service: Deactivated successfully.
ΠΈΡΠ½ 22 03:33:30 sys-net systemd[1]: Stopped user-runtime-dir@0.service - User Runtime Directory /run/user/0.
ΠΈΡΠ½ 22 03:33:30 sys-net systemd[1]: Removed slice user-0.slice - User Slice of UID 0.
ΠΈΡΠ½ 22 03:33:30 sys-net systemd[1]: user-0.slice: Consumed 1.765s CPU time.
ΠΈΡΠ½ 22 03:33:34 sys-net systemctl[1970]: Failed to connect to bus: ΠΠΎΡΠΈΡΠ΅Π»Ρ Π½Π΅ Π½Π°ΠΉΠ΄Π΅Π½
ΠΈΡΠ½ 22 03:33:34 sys-net qubes.StartApp+xfce4-terminal-dom0[1981]: ΠΠ΅ ΡΠ΄Π°Π»ΠΎΡΡ ΠΏΠΎΠ΄ΠΊΠ»ΡΡΠΈΡΡΡΡ ΠΊ ΠΌΠ΅Π½Π΅Π΄ΠΆΠ΅ΡΡ ΡΠ΅ΡΡΠΈΠΉ: ΠΠ΅ ΡΠ΄Π°Π»ΠΎΡΡ ΠΏΠΎΠ΄ΠΊΠ»ΡΡΠΈΡΡΡΡ ΠΊ ΠΌΠ΅Π½Π΅Π΄ΠΆΠ΅ΡΡ ΡΠ΅Π°Π½ΡΠΎΠ²: SESSION_MANAGER environment variable not defined
ΠΈΡΠ½ 22 03:34:10 sys-net sudo[2030]: user : TTY=pts/0 ; PWD=/home/user ; USER=root ; COMMAND=/usr/bin/journalctl -f
ΠΈΡΠ½ 22 03:34:10 sys-net sudo[2030]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1000)
ΠΈΡΠ½ 22 03:34:19 sys-net qrexec-agent[2033]: 2025-06-22 03:34:19.431 qrexec-agent[2033]: qrexec-agent-data.c:256:handle_new_process_common: executed: root:QUBESRPC qubes.USBAttach dom0 (pid 2035)
ΠΈΡΠ½ 22 03:34:19 sys-net qrexec-agent[2035]: pam_unix(qrexec:session): session opened for user root(uid=0) by (uid=0)
ΠΈΡΠ½ 22 03:34:19 sys-net systemd[1]: Created slice user-0.slice - User Slice of UID 0.
ΠΈΡΠ½ 22 03:34:19 sys-net systemd[1]: Starting user-runtime-dir@0.service - User Runtime Directory /run/user/0...
ΠΈΡΠ½ 22 03:34:19 sys-net systemd[1]: Finished user-runtime-dir@0.service - User Runtime Directory /run/user/0.
ΠΈΡΠ½ 22 03:34:19 sys-net systemd[1]: Starting user@0.service - User Manager for UID 0...
ΠΈΡΠ½ 22 03:34:19 sys-net (systemd)[2037]: pam_unix(systemd-user:session): session opened for user root(uid=0) by (uid=0)
ΠΈΡΠ½ 22 03:34:19 sys-net systemd[2037]: Queued start job for default target default.target.
ΠΈΡΠ½ 22 03:34:19 sys-net systemd[2037]: Created slice app.slice - User Application Slice.
ΠΈΡΠ½ 22 03:34:19 sys-net systemd[2037]: Created slice session.slice - User Core Session Slice.
ΠΈΡΠ½ 22 03:34:19 sys-net systemd[2037]: Reached target paths.target - Paths.
ΠΈΡΠ½ 22 03:34:19 sys-net systemd[2037]: Reached target timers.target - Timers.
ΠΈΡΠ½ 22 03:34:19 sys-net systemd[2037]: Starting dbus.socket - D-Bus User Message Bus Socket...
ΠΈΡΠ½ 22 03:34:19 sys-net systemd[2037]: Listening on dirmngr.socket - GnuPG network certificate management daemon.
ΠΈΡΠ½ 22 03:34:19 sys-net systemd[2037]: Listening on gcr-ssh-agent.socket - GCR ssh-agent wrapper.
ΠΈΡΠ½ 22 03:34:19 sys-net systemd[2037]: Listening on gnome-keyring-daemon.socket - GNOME Keyring daemon.
ΠΈΡΠ½ 22 03:34:19 sys-net systemd[2037]: Listening on gpg-agent-browser.socket - GnuPG cryptographic agent and passphrase cache (access for web browsers).
ΠΈΡΠ½ 22 03:34:19 sys-net systemd[2037]: Listening on gpg-agent-extra.socket - GnuPG cryptographic agent and passphrase cache (restricted).
ΠΈΡΠ½ 22 03:34:19 sys-net systemd[2037]: Listening on gpg-agent-ssh.socket - GnuPG cryptographic agent (ssh-agent emulation).
ΠΈΡΠ½ 22 03:34:19 sys-net systemd[2037]: Listening on gpg-agent.socket - GnuPG cryptographic agent and passphrase cache.
ΠΈΡΠ½ 22 03:34:19 sys-net systemd[2037]: pipewire-pulse.socket - PipeWire PulseAudio was skipped because of an unmet condition check (ConditionUser=!root).
ΠΈΡΠ½ 22 03:34:19 sys-net systemd[2037]: pipewire.socket - PipeWire Multimedia System Sockets was skipped because of an unmet condition check (ConditionUser=!root).
ΠΈΡΠ½ 22 03:34:19 sys-net systemd[2037]: Listening on dbus.socket - D-Bus User Message Bus Socket.
ΠΈΡΠ½ 22 03:34:19 sys-net systemd[2037]: Reached target sockets.target - Sockets.
ΠΈΡΠ½ 22 03:34:19 sys-net systemd[2037]: Reached target basic.target - Basic System.
ΠΈΡΠ½ 22 03:34:19 sys-net systemd[1]: Started user@0.service - User Manager for UID 0.
ΠΈΡΠ½ 22 03:34:19 sys-net systemd[1]: Started session-c4.scope - Session c4 of User root.
ΠΈΡΠ½ 22 03:34:19 sys-net systemd[2037]: Starting dbus.service - D-Bus User Message Bus...
ΠΈΡΠ½ 22 03:34:19 sys-net systemd[2037]: pipewire.service - PipeWire Multimedia Service was skipped because of an unmet condition check (ConditionUser=!root).
ΠΈΡΠ½ 22 03:34:19 sys-net systemd[2037]: filter-chain.service: Bound to unit pipewire.service, but unit isn't active.
ΠΈΡΠ½ 22 03:34:19 sys-net systemd[2037]: Dependency failed for filter-chain.service - PipeWire filter chain daemon.
ΠΈΡΠ½ 22 03:34:19 sys-net systemd[2037]: filter-chain.service: Job filter-chain.service/start failed with result 'dependency'.
ΠΈΡΠ½ 22 03:34:19 sys-net systemd[2037]: wireplumber.service: Bound to unit pipewire.service, but unit isn't active.
ΠΈΡΠ½ 22 03:34:19 sys-net systemd[2037]: Dependency failed for wireplumber.service - Multimedia Service Session Manager.
ΠΈΡΠ½ 22 03:34:19 sys-net systemd[2037]: wireplumber.service: Job wireplumber.service/start failed with result 'dependency'.
ΠΈΡΠ½ 22 03:34:19 sys-net systemd[2037]: pipewire-pulse.service - PipeWire PulseAudio was skipped because of an unmet condition check (ConditionUser=!root).
ΠΈΡΠ½ 22 03:34:19 sys-net systemd[2037]: Reached target default.target - Main User Target.
ΠΈΡΠ½ 22 03:34:19 sys-net systemd[2037]: Started dbus.service - D-Bus User Message Bus.
ΠΈΡΠ½ 22 03:34:19 sys-net systemd[2037]: Startup finished in 108ms.
ΠΈΡΠ½ 22 03:34:20 sys-net kernel: vhci_hcd vhci_hcd.0: pdev(0) rhport(0) sockfd(0)
ΠΈΡΠ½ 22 03:34:20 sys-net kernel: vhci_hcd vhci_hcd.0: devid(131078) speed(3) speed_str(high-speed)
ΠΈΡΠ½ 22 03:34:20 sys-net kernel: vhci_hcd vhci_hcd.0: Device attached
ΠΈΡΠ½ 22 03:34:20 sys-net kernel: usb 2-1: new high-speed USB device number 3 using vhci_hcd
ΠΈΡΠ½ 22 03:34:20 sys-net kernel: usb 2-1: SetAddress Request (3) to port 0
ΠΈΡΠ½ 22 03:34:20 sys-net kernel: usb 2-1: New USB device found, idVendor=12d1, idProduct=14db, bcdDevice= 1.02
ΠΈΡΠ½ 22 03:34:20 sys-net kernel: usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
ΠΈΡΠ½ 22 03:34:20 sys-net kernel: usb 2-1: Product: HUAWEI_MOBILE
ΠΈΡΠ½ 22 03:34:20 sys-net kernel: usb 2-1: Manufacturer: HUAWEI_MOBILE
ΠΈΡΠ½ 22 03:34:20 sys-net kernel: cdc_ether 2-1:1.0 eth0: register 'cdc_ether' at usb-vhci_hcd.0-1, CDC Ethernet Device, 00:1e:10:1f:00:00
ΠΈΡΠ½ 22 03:34:20 sys-net NetworkManager[598]: <info> [1750563260.6721] manager: (eth0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/6)
ΠΈΡΠ½ 22 03:34:20 sys-net kernel: cdc_ether 2-1:1.0 enx001e101f0000: renamed from eth0
ΠΈΡΠ½ 22 03:34:20 sys-net NetworkManager[598]: <info> [1750563260.6980] device (eth0): interface index 5 renamed iface from 'eth0' to 'enx001e101f0000'
ΠΈΡΠ½ 22 03:34:20 sys-net NetworkManager[598]: <info> [1750563260.7084] device (enx001e101f0000): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
ΠΈΡΠ½ 22 03:34:20 sys-net NetworkManager[598]: <info> [1750563260.7113] settings: (enx001e101f0000): created default wired connection 'ΠΡΠΎΠ²ΠΎΠ΄Π½ΠΎΠ΅ ΡΠΎΠ΅Π΄ΠΈΠ½Π΅Π½ΠΈΠ΅ 1'
ΠΈΡΠ½ 22 03:34:20 sys-net NetworkManager[598]: <info> [1750563260.7119] device (enx001e101f0000): carrier: link connected
ΠΈΡΠ½ 22 03:34:20 sys-net NetworkManager[598]: <info> [1750563260.7121] device (enx001e101f0000): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
ΠΈΡΠ½ 22 03:34:20 sys-net NetworkManager[598]: <info> [1750563260.7151] policy: auto-activating connection 'ΠΡΠΎΠ²ΠΎΠ΄Π½ΠΎΠ΅ ΡΠΎΠ΅Π΄ΠΈΠ½Π΅Π½ΠΈΠ΅ 1' (bb5e8606-7feb-3880-b7e9-9df64f5035bd)
ΠΈΡΠ½ 22 03:34:20 sys-net NetworkManager[598]: <info> [1750563260.7155] device (enx001e101f0000): Activation: starting connection 'ΠΡΠΎΠ²ΠΎΠ΄Π½ΠΎΠ΅ ΡΠΎΠ΅Π΄ΠΈΠ½Π΅Π½ΠΈΠ΅ 1' (bb5e8606-7feb-3880-b7e9-9df64f5035bd)
ΠΈΡΠ½ 22 03:34:20 sys-net NetworkManager[598]: <info> [1750563260.7156] device (enx001e101f0000): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
ΠΈΡΠ½ 22 03:34:20 sys-net NetworkManager[598]: <info> [1750563260.7162] manager: NetworkManager state is now CONNECTING
ΠΈΡΠ½ 22 03:34:20 sys-net NetworkManager[598]: <info> [1750563260.7163] device (enx001e101f0000): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
ΠΈΡΠ½ 22 03:34:20 sys-net NetworkManager[598]: <info> [1750563260.7169] device (enx001e101f0000): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
ΠΈΡΠ½ 22 03:34:20 sys-net NetworkManager[598]: <info> [1750563260.7174] dhcp4 (enx001e101f0000): activation: beginning transaction (timeout in 45 seconds)
ΠΈΡΠ½ 22 03:34:20 sys-net qrexec-agent[2035]: pam_unix(qrexec:session): session closed for user root
ΠΈΡΠ½ 22 03:34:20 sys-net qrexec-agent[2033]: 2025-06-22 03:34:20.729 qrexec-agent[2033]: qrexec-agent-data.c:288:handle_new_process_common: pid 2035 exited with 0
ΠΈΡΠ½ 22 03:34:22 sys-net NetworkManager[598]: <info> [1750563262.1738] dhcp6 (enx001e101f0000): activation: beginning transaction (timeout in 45 seconds)
ΠΈΡΠ½ 22 03:34:22 sys-net NetworkManager[598]: <info> [1750563262.1984] dhcp6 (enx001e101f0000): state changed new lease
ΠΈΡΠ½ 22 03:34:22 sys-net dbus-daemon[500]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.6' (uid=0 pid=598 comm="/usr/sbin/NetworkManager --no-daemon")
ΠΈΡΠ½ 22 03:34:22 sys-net NetworkManager[598]: <info> [1750563262.2002] device (enx001e101f0000): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
ΠΈΡΠ½ 22 03:34:22 sys-net systemd[1]: Starting NetworkManager-dispatcher.service - Network Manager Script Dispatcher Service...
ΠΈΡΠ½ 22 03:34:22 sys-net dbus-daemon[500]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
ΠΈΡΠ½ 22 03:34:22 sys-net systemd[1]: Started NetworkManager-dispatcher.service - Network Manager Script Dispatcher Service.
ΠΈΡΠ½ 22 03:34:22 sys-net NetworkManager[598]: <info> [1750563262.2432] device (enx001e101f0000): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
ΠΈΡΠ½ 22 03:34:22 sys-net NetworkManager[598]: <info> [1750563262.2438] device (enx001e101f0000): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
ΠΈΡΠ½ 22 03:34:22 sys-net NetworkManager[598]: <info> [1750563262.2440] manager: NetworkManager state is now CONNECTED_LOCAL
ΠΈΡΠ½ 22 03:34:22 sys-net NetworkManager[598]: <info> [1750563262.2441] device (enx001e101f0000): Activation: successful, device activated.
ΠΈΡΠ½ 22 03:34:22 sys-net systemd[1]: Stopping qubes-updates-proxy.service - Qubes updates proxy (tinyproxy)...
ΠΈΡΠ½ 22 03:34:22 sys-net tinyproxy[1248]: Shutting down.
ΠΈΡΠ½ 22 03:34:22 sys-net systemd[1]: qubes-updates-proxy.service: Deactivated successfully.
ΠΈΡΠ½ 22 03:34:22 sys-net systemd[1]: Stopped qubes-updates-proxy.service - Qubes updates proxy (tinyproxy).
ΠΈΡΠ½ 22 03:34:22 sys-net systemd[1]: Started qubes-updates-proxy.service - Qubes updates proxy (tinyproxy).
ΠΈΡΠ½ 22 03:34:22 sys-net tinyproxy-wrapper[2150]: Found tinyproxy at /usr/bin/tinyproxy
ΠΈΡΠ½ 22 03:34:22 sys-net tinyproxy-wrapper[2150]: WARNING: obsolete config item on line 14
ΠΈΡΠ½ 22 03:34:22 sys-net tinyproxy-wrapper[2150]: WARNING: obsolete config item on line 15
ΠΈΡΠ½ 22 03:34:22 sys-net tinyproxy-wrapper[2150]: WARNING: obsolete config item on line 16
ΠΈΡΠ½ 22 03:34:22 sys-net tinyproxy-wrapper[2150]: WARNING: obsolete config item on line 17
ΠΈΡΠ½ 22 03:34:22 sys-net tinyproxy[2150]: Initializing tinyproxy ...
ΠΈΡΠ½ 22 03:34:22 sys-net tinyproxy[2150]: Reloading config file
ΠΈΡΠ½ 22 03:34:22 sys-net tinyproxy[2150]: Reloading config file finished
ΠΈΡΠ½ 22 03:34:22 sys-net NetworkManager[598]: <info> [1750563262.7794] dhcp4 (enx001e101f0000): state changed new lease, address=192.168.8.103
ΠΈΡΠ½ 22 03:34:22 sys-net NetworkManager[598]: <info> [1750563262.7851] manager: NetworkManager state is now CONNECTED_SITE
ΠΈΡΠ½ 22 03:34:22 sys-net NetworkManager[598]: <info> [1750563262.7874] policy: set 'ΠΡΠΎΠ²ΠΎΠ΄Π½ΠΎΠ΅ ΡΠΎΠ΅Π΄ΠΈΠ½Π΅Π½ΠΈΠ΅ 1' (enx001e101f0000) as default for IPv4 routing and DNS
ΠΈΡΠ½ 22 03:34:23 sys-net ModemManager[589]: <info> [base-manager] couldn't check support for device '/sys/devices/platform/vhci_hcd.0/usb2/2-1': not supported by any plugin
ΠΈΡΠ½ 22 03:34:23 sys-net systemd[1]: Stopping qubes-updates-proxy.service - Qubes updates proxy (tinyproxy)...
ΠΈΡΠ½ 22 03:34:23 sys-net tinyproxy[2150]: Shutting down.
ΠΈΡΠ½ 22 03:34:23 sys-net systemd[1]: qubes-updates-proxy.service: Deactivated successfully.
ΠΈΡΠ½ 22 03:34:23 sys-net systemd[1]: Stopped qubes-updates-proxy.service - Qubes updates proxy (tinyproxy).
ΠΈΡΠ½ 22 03:34:23 sys-net systemd[1]: Started qubes-updates-proxy.service - Qubes updates proxy (tinyproxy).
ΠΈΡΠ½ 22 03:34:23 sys-net tinyproxy-wrapper[2160]: Found tinyproxy at /usr/bin/tinyproxy
ΠΈΡΠ½ 22 03:34:23 sys-net tinyproxy-wrapper[2160]: WARNING: obsolete config item on line 14
ΠΈΡΠ½ 22 03:34:23 sys-net tinyproxy-wrapper[2160]: WARNING: obsolete config item on line 15
ΠΈΡΠ½ 22 03:34:23 sys-net tinyproxy-wrapper[2160]: WARNING: obsolete config item on line 16
ΠΈΡΠ½ 22 03:34:23 sys-net tinyproxy-wrapper[2160]: WARNING: obsolete config item on line 17
ΠΈΡΠ½ 22 03:34:23 sys-net tinyproxy[2160]: Initializing tinyproxy ...
ΠΈΡΠ½ 22 03:34:23 sys-net tinyproxy[2160]: Reloading config file
ΠΈΡΠ½ 22 03:34:23 sys-net tinyproxy[2160]: Reloading config file finished
ΠΈΡΠ½ 22 03:34:33 sys-net systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Yesβ¦ Can you see the lines where the USB device appears? It is configured to act as an ethernet device, not a modem. A modem interface would probably create a device with a name similar to β/dev/ttyUSB0β.
The ethernet interface gives easy and fast networking, but any sending of SMS is probably in the web interface, except if either:
- there is a network port giving access to the AT interface, e.g. with an ssh access. You can either look in the manual (best!?), or install and run
nmap address-or-hostname, but giving the address or hostname you use in Firefox for the web interface. - There is another hidden usb device, but it should give some sign in journalctl. lsusb command can show a list.
lsusb
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 002: ID 12d1:14db Huawei Technologies Co., Ltd. E353/E3131
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 0627:0001 Adomax Technology Co., Ltd QEMU Tablet
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
nmap https://192.168.8.1
Starting Nmap 7.93 ( https://nmap.org ) at 2025-06-27 03:18 UTC
Unable to split netmask from target expression: "https://192.168.8.1"
WARNING: No targets were specified, so 0 hosts scanned.
Nmap done: 0 IP addresses (0 hosts up) scanned in 0.15 seconds
Tried to find something and so far the only useful thing seemed to be this: https://stackoverflow.com/questions/63214315/raspberry-pi-4-huawei-e3372-send-at-commands
It seems need to be switched from router mode to modem mode. Also every time I googled for its AT commands I always came across this list of commands (strange, but in English web there almost nothing related to its commands). And these commands are different from regular modemsβ commands and among these commands never were the ones related to sending / watching SMS.
Also seen warnings that if you enter wrong AT commands into the wrong modem model you can brick it. If the only commands intended for this modem are these commands then there probably no commands for SMS. ![]()
I would be appreciate if youβd check this my thread. Maybe you can tell what is wrong. Especially since itβs related to the USB stick configuring too. And since minicom is involved I would like to invite @KitsuneNoBaka 'cause he is the one who suggested minicom and seems to know how it works.
