As my occasional freezes and weird hiccups continue I have decided to wade through all of my colored journal messages, and I need help as I don’t understand a biggest part of them.
Here are all of my ERROR (priority 3 or higher) messages:
-- Logs begin at Sun 2023-04-30 23:00:01 +03, end at Fri 2023-05-05 13:59:11 +03. --
May 01 03:28:14 dom0 anacron[650995]: Can't find sendmail at /usr/sbin/sendmail, not mailing output
May 01 07:40:34 dom0 xscreensaver[4688]: pam_unix(xscreensaver:auth): conversation failed
May 01 07:41:06 dom0 xscreensaver[4688]: pam_unix(xscreensaver:auth): conversation failed
May 01 08:05:41 dom0 xscreensaver[4688]: pam_unix(xscreensaver:auth): conversation failed
May 01 08:16:15 dom0 xscreensaver[4688]: pam_unix(xscreensaver:auth): conversation failed
May 01 08:17:05 dom0 xscreensaver[4688]: pam_unix(xscreensaver:auth): conversation failed
May 01 08:17:24 dom0 xscreensaver[4688]: pam_unix(xscreensaver:auth): conversation failed
May 01 08:17:41 dom0 xscreensaver[4688]: pam_unix(xscreensaver:auth): conversation failed
May 01 08:24:03 dom0 xscreensaver[4688]: pam_unix(xscreensaver:auth): conversation failed
May 01 08:48:22 dom0 xscreensaver[4688]: pam_unix(xscreensaver:auth): conversation failed
May 01 08:54:54 dom0 xscreensaver[4688]: pam_unix(xscreensaver:auth): conversation failed
May 01 08:58:31 dom0 xscreensaver[4688]: pam_unix(xscreensaver:auth): conversation failed
May 01 08:59:16 dom0 xscreensaver[4688]: pam_unix(xscreensaver:auth): conversation failed
May 01 22:53:47 dom0 systemd-coredump[779406]: Process 4712 (xss-lock) of user 1000 dumped core.
Stack trace of thread 4712:
#0 0x00007236efec5fc2 g_logv (libglib-2.0.so.0 + 0x59fc2)
#1 0x00007236efec6233 g_log (libglib-2.0.so.0 + 0x5a233)
#2 0x00006024f0c7ebe5 screensaver_event_cb (xss-lock + 0x4be5)
#3 0x00006024f0c7ecdf xcb_event_dispatch (xss-lock + 0x4cdf)
#4 0x00007236efebe78f g_main_context_dispatch (libglib-2.0.so.0 + 0x5278f)
#5 0x00007236efebeb18 g_main_context_iterate.constprop.0 (libglib-2.0.so.0 + 0x52b18)
#6 0x00007236efebee33 g_main_loop_run (libglib-2.0.so.0 + 0x52e33)
#7 0x00006024f0c7decd main (xss-lock + 0x3ecd)
#8 0x00007236efc8c082 __libc_start_main (libc.so.6 + 0x27082)
#9 0x00006024f0c7e02e _start (xss-lock + 0x402e)
Stack trace of thread 4718:
#0 0x00007236efd5b86f __poll (libc.so.6 + 0xf686f)
#1 0x00007236efebeaae g_main_context_iterate.constprop.0 (libglib-2.0.so.0 + 0x52aae)
#2 0x00007236efebebe3 g_main_context_iteration (libglib-2.0.so.0 + 0x52be3)
#3 0x00007236efebec31 glib_worker_main (libglib-2.0.so.0 + 0x52c31)
#4 0x00007236efee87f2 g_thread_proxy (libglib-2.0.so.0 + 0x7c7f2)
#5 0x00007236efb83432 start_thread (libpthread.so.0 + 0x9432)
#6 0x00007236efd666d3 __clone (libc.so.6 + 0x1016d3)
Stack trace of thread 4720:
#2 0x00007236efebee33 g_main_loop_run (libglib-2.0.so.0 + 0x52e33)
#3 0x00007236f01126aa gdbus_shared_thread_func (libgio-2.0.so.0 + 0x1226aa)
-- Subject: Process 4712 (xss-lock) dumped core
-- Defined-By: systemd
-- Support: https://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- Documentation: man:core(5)
-- Process 4712 (xss-lock) crashed and dumped core.
-- This usually indicates a programming error in the crashing program and
-- should be reported to its vendor as a bug.
May 01 22:53:53 dom0 qrexec-policy-e[779408]: error calling qrexec-policy-agent in dom0
File "/usr/lib/python3.8/site-packages/qrexec/tools/qrexec_policy_exec.py", line 146, in execute
await super().execute(caller_ident)
File "/usr/lib/python3.8/site-packages/qrexec/policy/parser.py", line 643, in execute
raise ExecutionFailed("qrexec-client failed: {}".format(command))
qrexec.exc.ExecutionFailed: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,sys-net,1', '-E', 'QUBESRPC qubes.WindowIconUpdater+ sys-net keyword adminvm']
During handling of the above exception, another exception occurred:
File "/usr/lib/python3.8/site-packages/qrexec/tools/qrexec_policy_exec.py", line 167, in notify
await call_socket_service(guivm, service, source_domain, params)
File "/usr/lib/python3.8/site-packages/qrexec/server.py", line 108, in call_socket_service_local
reader, writer = await asyncio.open_unix_connection(path)
File "/usr/lib64/python3.8/asyncio/streams.py", line 111, in open_unix_connection
transport, _ = await loop.create_unix_connection(
File "/usr/lib64/python3.8/asyncio/unix_events.py", line 244, in create_unix_connection
await self.sock_connect(sock, path)
File "/usr/lib64/python3.8/asyncio/selector_events.py", line 496, in sock_connect
return await fut
File "/usr/lib64/python3.8/asyncio/selector_events.py", line 501, in _sock_connect
sock.connect(address)
ConnectionRefusedError: [Errno 111] Connection refused
May 01 22:53:53 dom0 qrexec-policy-e[779414]: error calling qrexec-policy-agent in dom0
qrexec.exc.ExecutionFailed: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,sys-whonix,112', '-E', 'QUBESRPC qubes.WindowIconUpdater+ sys-whonix keyword adminvm']
return await fut
May 01 22:53:53 dom0 qrexec[779408]: qubes.WindowIconUpdater: sys-net -> dom0: error while executing: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,sys-net,1', '-E', 'QUBESRPC qubes.WindowIconUpdater+ sys-net keyword adminvm']
May 01 22:53:53 dom0 qrexec-policy-e[779411]: error calling qrexec-policy-agent in dom0
qrexec.exc.ExecutionFailed: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,vpn-firewall,5', '-E', 'QUBESRPC qubes.WindowIconUpdater+ vpn-firewall keyword adminvm']
return await fut
May 01 22:53:53 dom0 qrexec[779411]: qubes.WindowIconUpdater: vpn-firewall -> dom0: error while executing: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,vpn-firewall,5', '-E', 'QUBESRPC qubes.WindowIconUpdater+ vpn-firewall keyword adminvm']
May 01 22:53:53 dom0 qrexec-policy-e[779407]: error calling qrexec-policy-agent in dom0
qrexec.exc.ExecutionFailed: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,tube,35', '-E', 'QUBESRPC qubes.WindowIconUpdater+ tube keyword adminvm']
return await fut
May 01 22:53:53 dom0 qrexec-policy-e[779412]: error calling qrexec-policy-agent in dom0
qrexec.exc.ExecutionFailed: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,sys-usb,33', '-E', 'QUBESRPC qubes.WindowIconUpdater+ sys-usb keyword adminvm']
return await fut
May 01 22:53:53 dom0 qrexec[779407]: qubes.WindowIconUpdater: tube -> dom0: error while executing: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,tube,35', '-E', 'QUBESRPC qubes.WindowIconUpdater+ tube keyword adminvm']
May 01 22:53:53 dom0 qrexec[779412]: qubes.WindowIconUpdater: sys-usb -> dom0: error while executing: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,sys-usb,33', '-E', 'QUBESRPC qubes.WindowIconUpdater+ sys-usb keyword adminvm']
May 01 22:53:53 dom0 qrexec[779414]: qubes.WindowIconUpdater: sys-whonix -> dom0: error while executing: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,sys-whonix,112', '-E', 'QUBESRPC qubes.WindowIconUpdater+ sys-whonix keyword adminvm']
May 01 22:53:53 dom0 qrexec-policy-e[779410]: error calling qrexec-policy-agent in dom0
qrexec.exc.ExecutionFailed: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,sys-vpn-air,4', '-E', 'QUBESRPC qubes.WindowIconUpdater+ sys-vpn-air keyword adminvm']
return await fut
May 01 22:53:53 dom0 qrexec[779410]: qubes.WindowIconUpdater: sys-vpn-air -> dom0: error while executing: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,sys-vpn-air,4', '-E', 'QUBESRPC qubes.WindowIconUpdater+ sys-vpn-air keyword adminvm']
May 01 22:53:53 dom0 qrexec-policy-e[779409]: error calling qrexec-policy-agent in dom0
qrexec.exc.ExecutionFailed: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,sys-firewall,3', '-E', 'QUBESRPC qubes.WindowIconUpdater+ sys-firewall keyword adminvm']
return await fut
May 01 22:53:53 dom0 qrexec[779409]: qubes.WindowIconUpdater: sys-firewall -> dom0: error while executing: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,sys-firewall,3', '-E', 'QUBESRPC qubes.WindowIconUpdater+ sys-firewall keyword adminvm']
May 01 22:53:58 dom0 libvirtd[1642]: internal error: Unable to reset PCI device 0000:00:14.0: no FLR, PM reset or bus reset available
May 01 22:54:15 dom0 systemd-cryptsetup[781748]: Device luks-7055418e-e799-4a4b-a089-721326c8882a is still in use.
May 01 22:54:15 dom0 systemd-cryptsetup[781748]: Failed to deactivate: Device or resource busy
May 01 22:54:15 dom0 systemd[1]: Failed unmounting mount xenstore file system.
-- Subject: A stop job for unit var-lib-xenstored.mount has finished
-- A stop job for unit var-lib-xenstored.mount has finished.
-- The job identifier is 16188 and the job result is failed.
-- Reboot --
May 01 22:54:56 dom0 kernel: ACPI Error: Aborting method \_SB.PCI0.SPI1.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20210730/psparse-529)
May 01 22:54:56 dom0 kernel: ACPI Error: Method execution failed \_SB.PCI0.SPI1.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20210730/uteval-68)
May 01 22:54:56 dom0 kernel: ACPI Error: Aborting method \_SB.PCI0.SPI2.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20210730/psparse-529)
May 01 22:54:56 dom0 kernel: ACPI Error: Method execution failed \_SB.PCI0.SPI2.FPNT._CRS due to previous error (AE_AML_INVALID_RESOURCE_TYPE) (20210730/uteval-68)
May 01 22:54:56 dom0 systemd-vconsole-setup[261]: /usr/bin/setfont failed with exit status 71.
May 01 22:54:57 dom0 systemd-vconsole-setup[468]: /usr/bin/setfont failed with exit status 71.
May 01 22:55:36 dom0 systemd-udevd[1162]: could not read from '/sys/module/intel_tcc_cooling/initstate': No such device
May 01 22:55:37 dom0 xenstored[1848]: Checking store ...
May 01 22:55:37 dom0 xenstored[1848]: Checking store complete.
May 01 22:56:58 dom0 libvirtd[1855]: internal error: Unable to reset PCI device 0000:00:14.0: no FLR, PM reset or bus reset available
May 02 00:52:58 dom0 pulseaudio[4333]: ALSA woke us up to write new data to the device, but there was actually nothing to write.
May 02 00:52:58 dom0 pulseaudio[4333]: Most likely this is a bug in the ALSA driver 'snd_hda_intel'. Please report this issue to the ALSA developers.
May 02 00:52:58 dom0 pulseaudio[4333]: We were woken up with POLLOUT set -- however a subsequent snd_pcm_avail() returned 0 or another value < min_avail.
May 02 03:33:53 dom0 anacron[33991]: Can't find sendmail at /usr/sbin/sendmail, not mailing output
May 02 13:51:43 dom0 kernel: i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=3230603 end=3230604) time 185 us, min 1017, max 1023, scanline start 1016, end 1028
May 02 15:42:14 dom0 xscreensaver[4362]: pam_unix(xscreensaver:auth): conversation failed
May 02 19:01:25 dom0 systemd-coredump[125609]: Process 4382 (xss-lock) of user 1000 dumped core.
Stack trace of thread 4382:
#0 0x00007a1b473d0fc2 g_logv (libglib-2.0.so.0 + 0x59fc2)
#1 0x00007a1b473d1233 g_log (libglib-2.0.so.0 + 0x5a233)
#2 0x00006532db357be5 screensaver_event_cb (xss-lock + 0x4be5)
#3 0x00006532db357cdf xcb_event_dispatch (xss-lock + 0x4cdf)
#4 0x00007a1b473c978f g_main_context_dispatch (libglib-2.0.so.0 + 0x5278f)
#5 0x00007a1b473c9b18 g_main_context_iterate.constprop.0 (libglib-2.0.so.0 + 0x52b18)
#6 0x00007a1b473c9e33 g_main_loop_run (libglib-2.0.so.0 + 0x52e33)
#7 0x00006532db356ecd main (xss-lock + 0x3ecd)
#8 0x00007a1b47197082 __libc_start_main (libc.so.6 + 0x27082)
#9 0x00006532db35702e _start (xss-lock + 0x402e)
Stack trace of thread 4394:
#0 0x00007a1b4726686f __poll (libc.so.6 + 0xf686f)
#1 0x00007a1b473c9aae g_main_context_iterate.constprop.0 (libglib-2.0.so.0 + 0x52aae)
#2 0x00007a1b473c9e33 g_main_loop_run (libglib-2.0.so.0 + 0x52e33)
#3 0x00007a1b4761d6aa gdbus_shared_thread_func (libgio-2.0.so.0 + 0x1226aa)
#4 0x00007a1b473f37f2 g_thread_proxy (libglib-2.0.so.0 + 0x7c7f2)
#5 0x00007a1b4708e432 start_thread (libpthread.so.0 + 0x9432)
#6 0x00007a1b472716d3 __clone (libc.so.6 + 0x1016d3)
Stack trace of thread 4388:
#2 0x00007a1b473c9be3 g_main_context_iteration (libglib-2.0.so.0 + 0x52be3)
#3 0x00007a1b473c9c31 glib_worker_main (libglib-2.0.so.0 + 0x52c31)
-- Subject: Process 4382 (xss-lock) dumped core
-- Process 4382 (xss-lock) crashed and dumped core.
May 02 19:01:30 dom0 qrexec-policy-e[125596]: error calling qrexec-policy-agent in dom0
return await fut
May 02 19:01:30 dom0 qrexec[125596]: qubes.WindowIconUpdater: sys-net -> dom0: error while executing: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,sys-net,1', '-E', 'QUBESRPC qubes.WindowIconUpdater+ sys-net keyword adminvm']
May 02 19:01:30 dom0 qrexec-policy-e[125600]: error calling qrexec-policy-agent in dom0
qrexec.exc.ExecutionFailed: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,sys-usb,5', '-E', 'QUBESRPC qubes.WindowIconUpdater+ sys-usb keyword adminvm']
return await fut
May 02 19:01:30 dom0 qrexec[125600]: qubes.WindowIconUpdater: sys-usb -> dom0: error while executing: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,sys-usb,5', '-E', 'QUBESRPC qubes.WindowIconUpdater+ sys-usb keyword adminvm']
May 02 19:01:30 dom0 qrexec-policy-e[125598]: error calling qrexec-policy-agent in dom0
return await fut
May 02 19:01:30 dom0 qrexec[125598]: qubes.WindowIconUpdater: sys-vpn-air -> dom0: error while executing: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,sys-vpn-air,4', '-E', 'QUBESRPC qubes.WindowIconUpdater+ sys-vpn-air keyword adminvm']
May 02 19:01:30 dom0 qrexec-policy-e[125595]: error calling qrexec-policy-agent in dom0
return await fut
May 02 19:01:30 dom0 qrexec[125595]: qubes.WindowIconUpdater: sys-firewall -> dom0: error while executing: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,sys-firewall,3', '-E', 'QUBESRPC qubes.WindowIconUpdater+ sys-firewall keyword adminvm']
May 02 19:01:30 dom0 qrexec-policy-e[125597]: error calling qrexec-policy-agent in dom0
qrexec.exc.ExecutionFailed: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,tube,9', '-E', 'QUBESRPC qubes.WindowIconUpdater+ tube keyword adminvm']
return await fut
May 02 19:01:30 dom0 qrexec-policy-e[125599]: error calling qrexec-policy-agent in dom0
qrexec.exc.ExecutionFailed: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,vpn-firewall,7', '-E', 'QUBESRPC qubes.WindowIconUpdater+ vpn-firewall keyword adminvm']
return await fut
May 02 19:01:30 dom0 qrexec[125597]: qubes.WindowIconUpdater: tube -> dom0: error while executing: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,tube,9', '-E', 'QUBESRPC qubes.WindowIconUpdater+ tube keyword adminvm']
May 02 19:01:30 dom0 qrexec[125599]: qubes.WindowIconUpdater: vpn-firewall -> dom0: error while executing: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,vpn-firewall,7', '-E', 'QUBESRPC qubes.WindowIconUpdater+ vpn-firewall keyword adminvm']
May 02 19:01:30 dom0 qrexec-policy-e[125601]: error calling qrexec-policy-agent in dom0
qrexec.exc.ExecutionFailed: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,sys-whonix,8', '-E', 'QUBESRPC qubes.WindowIconUpdater+ sys-whonix keyword adminvm']
return await fut
May 02 19:01:30 dom0 qrexec[125601]: qubes.WindowIconUpdater: sys-whonix -> dom0: error while executing: qrexec-client failed: ['/usr/lib/qubes/qrexec-client', '-d', 'dom0', '-c', 'SOCKET12,sys-whonix,8', '-E', 'QUBESRPC qubes.WindowIconUpdater+ sys-whonix keyword adminvm']
May 02 19:01:34 dom0 libvirtd[1855]: internal error: Unable to reset PCI device 0000:00:14.0: no FLR, PM reset or bus reset available
May 02 19:01:50 dom0 systemd-cryptsetup[127798]: Device luks-7055418e-e799-4a4b-a089-721326c8882a is still in use.
May 02 19:01:50 dom0 systemd-cryptsetup[127798]: Failed to deactivate: Device or resource busy
May 02 19:01:50 dom0 systemd[1]: Failed unmounting mount xenstore file system.
-- The job identifier is 3855 and the job result is failed.
-- Reboot --
