Hello
I wanted to try the tutorial from 51lieal (Playing with Qubes os) but now I’ve run into a problem where I don’t know what to do.
I have done the first part then switch back to the cli and select my ssd and usbstick.
But then I can only format qubes_dom0-swap
I can’t do anything with Qubes_dom0-root
When creating the partitions I got this error code :
Thin pool volume with chunk size 64.88 KiB can address at most 15.81 TIB of data.
Volume group “qubes_dom0” has insufficient free space (5139 extents): 7680 required.
You should redo everything and make sure you put a file system on each of them before you go back to the GUI, otherwise you won’t be able to do anything with them there.
Many thanks already. That worked
But now I have the problem with the usbstick which does not want to be formatted to /Boot/efi
It is written with bios boot but I am not sure if this is correct
It seems that you’re booting in legacy BIOS mode and not in UEFI mode so you can’t use EFI partition.
In that case you can use just a single /boot partition without a need to setup /boot/efi partition.
unfortunately this does not work and the cli shows me that a /boot/efi partion is needed.
see error →
Failed to find a suitable stage1 device: EFI system partition cannot be of type biosboot; EFI system partition cannot be of type ext2; EFI-
System partition must be mounted on one of the /boot/efi; EFI-
system partition cannot be of type None.
this is mixed up on sdb1 is bios boot, and on sdb2 is efi boot. so if i format fat32 to efi boot, it works. then
i format sdb1 to ext4 and go into cli but i can’t enter /boot there
after reboot the same problem again. EFI partition recognized again and can be edited and bios boot cannot be edited to /boot
I have now reinstalled the usb again and have
dd if=/dev/urandom of=/dev/sda bs=1M status=progress
after that
EFI partition
sgdisk -n 0:0:+200MiB -t 0:ef02 /dev/sda
gdisk /dev/sda
sda1 (BIOS boot):
n
enter
enter
+1M
ef02
sda2 (EFI System - /boot/efi):
n
enter
enter
+512M
ef00
sda3 (Linux filesystem - /boot):
n
enter
enter
+512M
enter
sda4 (luks):
n
enter
enter
enter
enter
w
(Y)
I think there is an error in the guide and you don’t actually need to create BIOS Boot type partition, you just need to create simple ext4 partition:
EFI Partition
