Hello guys,
I fucked up with my power manager settings while trying to disable the automatic screen lock while being on plug, but I fucked up with the settings.
Can anyone give me screenshots of his current default settings, so I can copy?
It’s really dumb I know, but thanks to anyone who will do it. System Tools > Power Manager
Not really Qubes OS specific.
(user@dom0 ~)$ sudo find / -name "*power-manager.xml*"
/etc/xdg/xfce4/xfconf/xfce-perchannel-xml/xfce4-power-manager.xml.qubes
/etc/xdg/xfce4/xfconf/xfce-perchannel-xml/xfce4-power-manager.xml.xfce4
/home/user/.config/xfce4/xfconf/xfce-perchannel-xml/xfce4-power-manager.xml
If you remove the user config file, you will have the default values (need logout to take effect).
rm /home/user/.config/xfce4/xfconf/xfce-perchannel-xml/xfce4-power-manager.xml
Xfce4 settings are managed by Xfconf-query.
https://docs.xfce.org/xfce/xfconf/xfconf-query
You could also use the -r, --reset and -R, --recursive options.
(user@dom0 ~)$ xfconf-query -h
Usage:
xfconf-query [OPTION…] - Xfconf commandline utility
Help Options:
-h, --help Show help options
Application Options:
-V, --version Version information
-c, --channel The channel to query/modify
-p, --property The property to query/modify
-s, --set The new value to set for the property
-l, --list List properties (or channels if -c is not specified)
-v, --verbose Verbose output
-n, --create Create a new property if it does not already exist
-t, --type Specify the property value type
-r, --reset Reset property
-R, --recursive Recursive (use with -r)
-a, --force-array Force array even if only one element
-T, --toggle Invert an existing boolean property
-m, --monitor Monitor a channel for property changes
