From early today I have been having problems where my Qubes that runs through says-whonix have been having connectivity problems and internet seems to move extremely slow. I tried restarting tor control panel multiple times and it works for a bit then goes back to same issues. Btw I updated my Qubes today with latest updates that’s I saw
Tor being slow is a Tor problem, not a Qubes or Whonix problem.
There are no Tor problems as far as I can tell. I do have a number of tor servers and clients running. Do you have Tor software in a different VM? Unfortunately I don’t use stock whonix to tell you if that is the problem.
You should try a few Tor configurations before making up your mind. I hope they are not comming for you…
