Hi, whenever I visit a website and scroll the screen is cracking up. It’s not convenient at all. What I mean is I get very thin transparent lines when I scroll and they vanish when I stop scrolling. This didn’t happen before, but after I reinstalled qubes, this seems to be the issue. Is there any solution? I am on latest stable release.
That’s because Qubes doesn’t use GPU acceleration.
Disable smooth scrolling, and you’ll get accustomed to it.
How do I disable that?
Moved to User Support
