Multiple problems involving sys qube, login and printing
Hello all,
I’ve got a few problems that all seem to have come at once for no real reason I can see.
  1. I set up a sys qube called sys-mulvad to run my VPN following a guide on here. It was working flawlessly until a few days ago. Now when the little symbol appears in the system tray on the top right of the screen and I tell it to connect it says it’s can’t and has timed out.
  2. Also when I boot up my machine I am able to put in the decryption passphrase and it all loads up but when I get to the qubes login screen it inexplicably will not let me put in my password. The keyboard will not input characters. Granted this is a sporadic problems and happens around 40% of the time but until a fortnight ago it wasn’t happening at all.
  3. I did make a post on this a while ago but since i don’t recall it being answered I’ll include it here too though it is not as crucial as the first two. My qubes don’t seem to be able to send data to my wireless printer. I have the HPLIP software installed but when I attempt to configure the printer, although it recognizes the thing, the configuration won’t save or be registered and no printing will happen.
I realize that I have not provided much information aside from the actual problem but that is because I’m not sure what info is needed or where to access it so if people would be ok to tell me what log, file etc they need to see I will happily provide it.
Thanks
Presumably you have to reboot when this happens? On the next boot you could look through the journal of the previous boot and current boot, compare them against each other and see if you can spot a germane error, maybe something USB related if you’re using a USB keyboard.
Journal of the current boot:
[user@dom0 ~]$ sudo journalctl -b
Journal of the previous boot:
[user@dom0 ~]$ sudo journalctl -b -1
