Hi! Please help me make sure I understand the following and correct me where needed.
I’m building a new computer and this is a good time for me to switch to Qubes. I have used it enough to test and use to understand it and I like it. The new computer I am building will be able to support 6 monitors and I want to connect 6 monitors. I will be using a Nvidia GPU that supports 4 monitors and connect 2 more via a daisy chain.
Will Qubes support multiple monitors with a GPU?
If not, will Qubes support multiple monitors using the available ports on the motherboard along with however many I can daisy chain?
Any suggestions welcomed. Thank you for any help I can get.
