Multihop in mullvad vpn
When i try to use mullvad with multihop i dont get a internet connection but if i use it normaly it works does anyone know how to fix this
also another issue that im facing is that when i click on wifi networks and then my network it freezes and takes extremely long before it prompts me to fill in my wifi password i never had this issue in previous versions of qubes os
so when i click on the taskbar on the wifi thing where you connect then after that i click on available networks and then i click on my wifi network but when i do that it freezes when its loading and then after like 30 seconds it loads the password screen where i have to fill in my wifi passowrd
It will be difficult to help without application logs. I don’t know where the Mullvad app stores its’ logs, but maybe MV support could help here. It’s possible that the app outputs some logs to the system journal (viewable by typing sudo journalctl -f before connecting in the MV app in the terminal).
Try reducing the MTU to 1280. The MTU can be changed in Settings → VPN Settings
