I have been using mullvad in one app vm with no problem but I can’t manage to get it to launch with a GUI. I am using this in a debian vm. I also have it installed on another pc which has Zorin on it. Using the same deb package in Zorin it incorporates itself into the applications and I can launch a gui without a problem. Using the same method in a debian based app vm in qubes however does not present itself in qubes settings > applications but it does install as I can launch it and use it from the terminal.
This may not get much help here but does anyone know how to access/install a gui for use with mullvad in qubes?
I know that I should probably set up a mullvad qube for networking but that requires skills that I will really need to put some time aside for, so for now it works in one vm for me.
Thanks for any help I can get here. Very much appreciated.
