MSI MAG Z790 Tomahawk MAX WIFI
  1. Boot device not recognized after installation. Copy boot files to /boot/efi/EFI/BOOT
  2. Hardware sensor not supported with default installation kernel but supported by installing with Kernel-Latest option. Enter ‘nct6683’ in modules.conf.
  3. WIFI7 adapter currently not supported.
Will you submit an HCL report?
I thought I did but here is an update. Note it does not report my nvme drives.
layout:
  'hcl'
type:
  'Desktop'
hvm:
  'yes'
iommu:
  'yes'
slat:
  'yes'
tpm:
  '2.0'
remap:
  'yes'
brand: |
  Micro-Star International Co., Ltd.
model: |
  MS-7E25
bios: |
  A.80
cpu: |
  12th Gen Intel(R) Core(TM) i9-12900K
cpu-short: |
  FIXME
chipset: |
  Intel Corporation 12th Gen Core Processor Host Bridge/DRAM Registers [8086:4660] (rev 02)
chipset-short: |
  FIXME
gpu: |
  Intel Corporation AlderLake-S GT1 [8086:4680] (rev 0c) (prog-if 00 [VGA controller])
gpu-short: |
  FIXME
network: |
  Intel Corporation Ethernet Controller I225-V [8086:15f3] (rev 03)
  Qualcomm Technologies, Inc Device [17cb:1107] (rev 01)
memory: |
  65207
scsi: |
usb: |
  1
certified:
  'no'
versions:
  - works:
      'FIXME:yes|no|partial'
    qubes: |
      R4.2.4
    xen: |
      4.17.5
    kernel: |
      6.12.11-1
    remark: |
      FIXME
    credit: |
      FIXAUTHOR
    link: |
      FIXLINK
Also previously mentioned #1 has been resolved.
Remarks
Something new; USB 3.2 Gen 2x2 port does not allow compatible 20 Gbps drives to attach. Probably not a Qubes issue though.
Qubes-HCL-Micro_Star_International_Co___Ltd_-MS_7E25-20250303-003031.yml (902 Bytes)
