Hello,
i want to move a file from dom0 to a domU with the dialog box.
My use case is taking screenshots. In any perceivable case i need those screenshots to go into a domU and i really don’t need them in dom0.
Usually i do:
- Press my screenshot shortcut
- Take the screenshot
- Choose where do save the screenshot
- Open a dom0 terminal
qvm-move-to-vm
I want to modify my shortcut so my process would be:
- Choose the target qube for the screenshot
Saving the screenshot and moving it should be done automatically.
To choose the target qube, i could open a dom0 terminal to prompt for it. This would not be my preferred solution.
As the qvm-move dialog box has convenient autocomplete for qube destinations, i would like to use this from within dom0.
Is there a better way to do this as: Creating a new dispvm, qvm-move-to-vm to it, and then qvm-copy to the real destination?
