Mounting USB drive in 4.2.4
So I’m bad at doing backups, so it’s been a while since I tried…
After plugging in the USB drive, it refuses to appear in the sys-usb cube so I can point my backup at it.
I also cannot attach to a app-vm; error mentions something about a “qubes-app-linux-usb-proxy blob.”
In searching the forums, I see issues like this with 4.3, but not 4.2.4.
I am running an up to date 4.2.4, debian-12 based sys-usb dvm.
Appreciate any thoughts.
Thanks.
First, check whether there are any hardware issues by running this command in the sys-usb terminal:
lsusb
If nothing appears, it may indicate a hardware or controller issue.
If devices do appear and there is no hardware problem, then check the USB proxy package by running:
sudo apt list --installed | grep qubes
Look for qubes-app-linux-usb-proxy. If it is missing, install it using:
sudo apt install qubes-app-linux-usb-proxy
Then restart your sys-usb and plug the USB drive in again.
Thanks for the help!
Interesting results:
lsusb does show the device, so good there.
The file is not installed, but upon trying to install I get:
user@debian-12-custom:~$ sudo apt-get install qubes-app-linux-usb-proxy
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
E: Unable to locate package qubes-app-linux-usb-proxy
I checked the sources file, and the repository is being checked:
user@debian-12-custom:/etc/apt/sources.list.d$ sudo apt update
Hit:1 Index of /debian bookworm InRelease
Hit:3 Index of /debian-security bookworm-security InRelease
Get:4 Index of /debian bookworm-backports InRelease [59.4 kB]
Hit:6 Index of /deb/r4.2/vm/ bookworm InRelease
Hit:7 Index of /r4.2/vm/ bookworm InRelease
What am I missing?
Thanks!
I think it is better to remove the sys-usb qube and create it again.
First, please read the official documentation:
https://doc.qubes-os.org/en/latest/user/advanced-topics/usb-qubes.html
Removing sys-usb
  1. Shut down the USB qube.
  2. In Qubes Manager, right-click on the USB qube and select “Remove VM.”
  3. Open the file /etc/default/grub in dom0.
  4. Find the line(s) that begin with GRUB_CMDLINE_LINUX.
  5. If rd.qubes.hide_all_usb appears in those lines, remove it.
  6. Save and close the file.
  7. Run the following command in dom0:
  1. Reboot the system.
Creating sys-usb again
Run in dom0:
sudo qubesctl state.sls qvm.sys-usb
Manual method:
  1. Read the PCI devices documentation and identify your USB controller.
  2. Create a new qube and name it sys-usb.
  3. Go to the qube settings → Devices tab.
  4. Move the USB controller from “Available” to “Selected”.
  5. Apply changes and restart the qube.
  6. Enable: “Start VM automatically on boot”
