Motherboard recommendation for Ryzen 9 7950X and 128 gb of RAM
I am looking for motherboard recommendations. I’d like to have a box which works great with Qubes.
Thanks!
  • Peripherals: A non-USB keyboard or multiple USB controllers
source:
Look for any AM5 motherboard with such features.
Motherboards database:
I’m using the MSI MAG X670E Tomahawk WiFi, and I’ve not had any issues with Qubes OS compatibility or stability.
The CPU I use is the 9950X, but I don’t think there is any difference between the two CPUs.
Stick to MSI, they seem to work well with Qubes. I have two (AMD and Intel CPU).
I prefer ones with at least a combo PS/2 port. Failing that, extra USB controllers or add a PCI card so you can isolate USB keyboard
