Monero node : no incoming connections via tor in whonix app-qube
I’m actually struggling with my monero node. I can’t have incoming connections through tor.
I run the last monero version (from binaries, verified) in whonix-18-ws, and sys-whonix-18-gateway as netVM
What I did :
  • in sys-whonix : torrc.d/50_user.conf edited to add as HiddenServiceDir and the 2 HiddenServicePorts 18089 and 18084 (with the monero-ws ip)
  • in monero-ws : edited the whonix-firewall settings with EXTERNAL_OPEN_PORTS+=" 18089" and the same for 18084.
  • reloaded sys-whonix tor and monero-ws firewall
Actually some results :
  • I can reach my xxxxx.onion:18089/get_info
  • sys-whonix seems to work and forward the connections to monero-ws. For testing, I installed nginx and tested the two ports 18089 and 18084 : both of them are then reachable from xxxxx.onion:18089 or xxxxx.onion:18084 (after that, I removed nginx)
  • in monerod outputs : I have outcoming ipv4 and tor connections ; but no tor incoming (no ipv4 incoming connections because of a NAT)
  • on another computer, I have a monero node running without any problem on clearnet and tor, with incoming connections on both (as not behind a NAT).
I’m so pretty sure the problem comes from a misconfiguration of monerod.
Here’s my config file :
# /etc/monero/monerod.conf
data-dir=/working/directory/to/data   # Blockchain storage location
check-updates=disabled         # Do not check DNS TXT records for a new version
enable-dns-blocklist=1         # Block known malicious nodes
enforce-dns-checkpointing=1
db-sync-mode=safe				# Slow but reliable db writes
log-file=/working/directory/to/.bitmonero/bitmonero.log
log-level=0                    # Minimal logs, WILL NOT log peers or wallets connecting
max-log-file-size=10000000  	#set to 10Mo
max-log-files=5
p2p-bind-ip=0.0.0.0            # Bind to all interfaces (the default)
p2p-bind-port=18080            # Bind to default port
no-igd=1                       # Disable UPnP port mapping for tor or direct ip
#RPC
rpc-restricted-bind-ip=0.0.0.0 	# Bind to all interfaces (the Open Node)
rpc-restricted-bind-port=18089 	# Bind to a new RESTRICTED port (the Open Node)
rpc-ssl=autodetect             	# Use TLS if client wallet supports it; [enabled|disabled|(default)autodetect]
# ZMQ
no-zmq=1                       	# Disable ZMQ RPC server
max-txpool-weight=384354560   	# Maximum unconfirmed transactions pool size in bytes
out-peers=32             		# Default 12
in-peers=32               		# The default is unlimited; we prefer to put a cap on this
limit-rate-up=48576
limit-rate-down=48576
# Tor - broadcast transactions originating from connected wallets over Tor/I2P
tx-proxy=tor,<sys-whonix-ip>:9153,12,disable_noise
anonymous-inbound=xxxxx.onion:18084,127.0.0.1:18084
disable-rpc-ban=1
print_cn output for example:
print_cn
Remote	Host	Type	SSL	Peer	id	Support	Flags	Recv/Sent	(inactive,sec)	State	Livetime(sec)	Down	(kB/s)	Down(now)	Up	(kB/s)	Up(now)
OUT	xxxxxxx:18080	IPv4	no	aaaaaaaaaaaaaaa	1	33668(1)/30069(4)	normal	52	0	0	0	0
OUT	xxxxxxx:18080	IPv4	no	aaaaaaaaaaaaaaa	1	104760(1)/107940(3)	normal	151	0	0	0	1
OUT	xxxxxxx:18080	IPv4	no	aaaaaaaaaaaaaaa	1	179595(2)/179679(6)	normal	254	0	0	0	0
OUT	xxxxxxx:18080	IPv4	no	aaaaaaaaaaaaaaa	1	339226(6)/338550(4)	normal	494	0	0	0	0
OUT	xxxxxxx:18080	IPv4	no	aaaaaaaaaaaaaaa	1	597506(3)/568872(2)	normal	861	0	0	0	0
OUT	xxxxxxx:18080	IPv4	no	aaaaaaaaaaaaaaa	1	1537143(1)/1496180(4)	normal	2847	0	0	0	0
OUT	xxxxxxx:18080	IPv4	no	aaaaaaaaaaaaaaa	1	673411(18)/681223(4)	normal	1164	0	1	0	0
OUT					Tor	no	1	0	83350(31)/55420(31)	normal	226	0	0	0	0
OUT					Tor	no	1	0	114393(24)/70033(24)	normal	701	0	0	0	0
OUT					Tor	no	1	0	104456(18)/70333(18)	normal	859	0	0	0	0
OUT					Tor	no	1	0	89031(56)/30317(57)	normal	260	0	1	0	0
OUT					Tor	no	1	0	120236(56)/71358(57)	normal	1105	0	0	0	0
OUT					Tor	no	1	0	112466(56)/71584(57)	normal	1423	0	0	0	0
OUT					Tor	no	1	0	120861(4)/71531(4)	normal	949	0	0	0	0
OUT					Tor	no	1	0	123677(56)/72330(57)	normal	1439	0	0	0	0
OUT					Tor	no	1	0	125877(43)/73828(43)	normal	1629	0	0	0	0
OUT					Tor	no	1	0	65430(41)/45578(41)	normal	140	0	0	0	1
OUT					Tor	no	1	0	126164(42)/75111(42)	normal	2223	0	0	0	0
2026-02-13	10:22:42.384 W No incoming connections - check firewalls/routers allow port 18080
Any ideas ?
Is there something to deal with anonymous-inbound line ? igd ? p2p ports ?
can you try, if you can reach my node:
s4olc24.......onion:18089
Try also posting this on whonix forum
thanks for reply,
just to be sure, which way ?
I can reach your node via tor-browser (with /get_info); but should I test another way too ?
yeah thanks, I gonna try there too
(yeah thanks, I gonna try there too)
Sorry I edited the previous post, and don’t know how to delete this one
Meanwhile, I tried to open the gateway firewall,
/usr/local/etc/whonix_firewall.d/50_user.conf
EXTERNAL_OPEN_PORTS+=" 18089 "
EXTERNAL_OPEN_PORTS+=" 18084 "
but it didn’t change anything
was thinking you have problems in the Monero-gui app, and so I thought you should test it there too
OK,
I’m just using the monerod deamon, to run a node ; I don’t have any wallet ; nor gui app installed
