--get-whitelist
Get a list of .desktop files corresponding to applications to be included in the menu.
--set-whitelist PATH
Set the list of applications to be included in the menu. The PATH can be either a path to file containing a list of .desktop files, or a single hyphen ('-') to read from
standard input.
--set-default-whitelist PATH Set the default list of applications to be included in the menus of VMs based on this template. Should only be used for TemplateVMs .The PATH
can be either a path to file containing a list of .desktop files, or a single hyphen ('-') to read from standard input.
--get-available [EXPERIMENTAL] [REQUIRES --i-understand-format-is-unstable]
List all available applications for the VM. The current format is UNSTABLE. The applications are listed as hyphen-separated pairs consisting of file name and application
name.
Remarks: ${apps_list} must match the file name(s) in /usr/share/applications
it can be more than one but separated with space and with the file ending .desktop
“app1.desktop app2.desktop …”. It must be a list if you add one by one it will be overwritten - it expects a list.
