I’ve gotten to the point where I have my Ledger connecting to my browser correctly in my personal Qube; but, it cannot connect in my minimal Qube. I can see it, however metamask does not finish the process. Anyone know which package I should add?
Can’t say that I do but, here’s a path that ought lead you to it …
A) While you try to use/connect your wallet, watch the logs of your minimal template with:
# journalctl -f
or
# journalctl -f -xe
or
# journalctl -f | grep ledger
(Prefix with sudo if not logged in w/root-level permissions)
B) Look for any ledger-oriented errors which may offer a hint toward to the missing package(s)
C) Obtain a list of packages installed in each qubes with:
dnf list --installed | awk '{print $1}' >> out-1
dnf list --installed | awk '{print $1}' >> out-2
D) Diff the files with:
diff out-1 out-2
Hope it works out!
try install qubes-usb-proxy
I read OP’s statement of “I can see it” to indicate that they’ve already done so …
Yeah, it shows up to Brave, even without that package. But, I can’t interact with it.
Logs have not proven fruitful so far. On the full Fedora I just get a couple messages after attaching to metamask.
This is what I see in dmesg after the Ledger is successfully paired:
[ 514.222296] vhci_hcd: unlink->seqnum 32
[ 514.222334] vhci_hcd: urb->status -104
[ 514.849700] vhci_hcd: unlink->seqnum 38
[ 514.849785] vhci_hcd: urb->status -104
[ 515.471025] vhci_hcd: unlink->seqnum 44
[ 515.471069] vhci_hcd: urb->status -104
[ 516.098122] vhci_hcd: unlink->seqnum 50
[ 516.098162] vhci_hcd: urb->status -104
[ 516.721124] vhci_hcd: unlink->seqnum 56
[ 516.721169] vhci_hcd: urb->status -104
[ 517.348496] vhci_hcd: unlink->seqnum 62
[ 517.348533] vhci_hcd: urb->status -104
[ 527.022036] vhci_hcd: unlink->seqnum 68
[ 527.022076] vhci_hcd: urb->status -104
Have you installed the udev rules?
Guess I’m just going to be doing a search for the package. Can prune a couple hundred. See if installing everything works, and then search by cutting in half.
On Debian minimal with Chrome, no special packages are required in the browser qube’s template.
