Remarks
I have bought a mini pc on Aliexpress with an i5.
So far I could install Qubes OS 4.2 and it boots fast.
But somehow Qubes says that Vt-d is not enabled but BIOS says it is.
Currently I use the workaround with qubes.enable_insecure_pv_passthrough
I’ll try to figure out why Vtd is not recognized.
I had only 4.2-alpha by the hand. I will check if the issue happens also with the final 4.2.
Update
With the final Qubes 4.2 release everything works fine and fast ![]()
No need to use the mentioned workaround above.
Great thanks to the devs
I’ve updated the HCL report.
Qubes-HCL-INTEL-ADL_P_AIO_V.yml (960 Bytes)
