最小有线网络 VM 设计
参考论坛和群友的讨论,基于最小化的 debian13-minimal,设计一个用于有线网络和手机 USB 共享网络的最小 VM。
所需软件包
网络支持
所需软件包:
qubes-core-agent-networkingdhcpcd- 可能还需要安装相应的
firmware*软件包,请根据实际硬件自行确定并安装。
安装命令:
apt install --no-install-recommends qubes-core-agent-networking dhcpcd
安装完成后,将相关网络服务设置为开机自动启动。
手机文件传输与刷机支持
所需软件包:
adbfastboot
安装命令:
apt install --no-install-recommends adb fastboot
可选操作
为了进一步减少系统组件和潜在攻击面,可以考虑移除以下软件包:
xorg*qubes-gui-agent- 其他不需要的图形界面相关组件
移除图形界面相关组件后,在操作 sys-usb 或 sys-usbnet 时,需要打开 Qubes Manager,选中对应的 qube,右键点击 Open console in qube,然后在弹出的 DispVM 终端中执行相关操作。
Minimal Wired Network VM Design
Based on discussions from forums and community groups, this design uses a minimal debian13-minimal installation to create a minimal VM for wired networking and USB tethering through a mobile phone.
Required Packages
Network Support
Required packages:
qubes-core-agent-networkingdhcpcd- The appropriate
firmware*packages may also be required. Determine which firmware packages are needed for the actual hardware and install them as necessary.
Install the packages with:
After installation, configure the relevant network services to start automatically at boot.
Android File Transfer and Flashing Support
Required packages:
adbfastboot
Optional Steps
To further reduce the number of system components and minimize the potential attack surface, consider removing the following packages:
xorg*qubes-gui-agent- Other unnecessary graphical interface components
After removing the graphical interface components, operations involving sys-usb or sys-usbnet require opening Qubes Manager, selecting the corresponding qube, right-clicking it, and choosing Open console in qube. The required commands can then be executed in the terminal of the launched DispVM.
